976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 12:04 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brake help please
Author Topic: brake help please  (Read 2228 times)
motomagII
brake help please
« on: February 09, 2006, 08:59 PM »
got my supercross today and it has got brake i not seen before apparently its cantilever brakes how do i set them up etc as not got clue pics would be nice .also would v brakes or 9900 brakes fit the brake mounts instead of these 'thanks
Re: brake help please
« Reply #1 on: February 09, 2006, 09:04 PM »
greg take one side off if its got a hole for the spring its the canti ones if no hole then normal ad brakes lol
« Reply #2 on: February 09, 2006, 09:16 PM »
they are cantis mate
used to be popular-ish in the late ninties
i run a canti on the front of my flatland bike for a while
you can run v brakes instead
or get a straddle cable and run the cantis. they should work ok
dont forget you will need a v brake lever
motomagII
« Reply #3 on: February 09, 2006, 09:18 PM »
hi mate thanks for the info .does the straddle cable just float ?how do you adjust /set the brake up as there is no tension adjuster on there ?
« Reply #4 on: February 09, 2006, 09:19 PM »
yup it just floats
there should be an anchor point further up. sometimes there is an adjuster there. or use the lever as the adjuster
you may need an anchor that attaches to the brake bridge
motomagII
« Reply #5 on: February 09, 2006, 09:21 PM »
whats the anchor please .link to anyone selling em ?dont ask for much do i lol
Offline Steve P
« Reply #6 on: February 09, 2006, 09:23 PM »
I don't think AD's will fit this frame as the lugs are lower on the rear stay . . . AD's will not give enough rear wheel clearance and scrub the rear tyre
« Reply #7 on: February 09, 2006, 09:23 PM »
no idea who sells them
find a moutainbike shop i reckon
