975755
TattooedYorkie
September 23, 2024, 05:31 AM
Sealed Bearings
Topic: Sealed Bearings (Read 561 times)
coco
Sealed Bearings
February 22, 2009, 08:17 PM »
My front wheel bearings have just started squeaking and sound very dry. They are sealed but has anyone had any success with removing the seal and re-greasing? If not does anyone know where I can get replacement bearings (I dont want the hub) and cost?
CD17
Berm Worm
Re: Sealed Bearings
February 22, 2009, 10:45 PM »
What hub is it
& is it for a rider or a show
Replacement sealed bearings, if brought from a industrial bearing dealer do not cost a lot at all
You could try soaking them in something, but this will only thin out the grease & make it run out in time
coco
Re: Sealed Bearings
February 23, 2009, 08:49 PM »
Its for a cruiser that I`m racing. The hubs are pretty standard issue and of no fancy pants make. Reckon I`ll take it to an engineers somewhere and they should be able to match the size. Just found some on internet for about a fiver. Need to double check the size.
Sealed Bearings
