975821 Posts in 138945 Topics by 6374 Members - Latest Member: Boults December 25, 2024, 03:17 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  paint stripping
Author Topic: paint stripping  (Read 683 times)
paint stripping
« on: February 21, 2009, 01:43 PM »
whats the best route to take on this'some one mentioned sand blasting your frame and forks,is this the best method?any help appeciated guys :daumenhoch:
Re: paint stripping
« Reply #1 on: February 21, 2009, 03:48 PM »
it all depends on how you are going to re-finish it, shot blast if you are going to powder coat, but nitro mores if you are going to have chromed or sprayed....
Re: paint stripping
« Reply #2 on: February 21, 2009, 04:14 PM »
its going for a chrome so maybe nitro mores is the best direction.fired the same question to those across the pond and someone said about plastic bead blasting????cheers for the help meticus.anyone else????? :daumenhoch:
Re: paint stripping
« Reply #3 on: February 21, 2009, 06:17 PM »
dont think the polishers at the chromers will be happy if you have it blasted, as it has to be polished from bare steel to a mirror finish if you want a nice chrome job.....
fouronethreeoh!
Re: paint stripping
« Reply #4 on: February 21, 2009, 07:10 PM »
Plastic media is fine for steel but a little harsh for aluminium.
It only removes paint though, not corrosion. If you want rust removal aswell, aluminium oxide media is good.
If you go for blasting, block up the frame holes as you end up with it in the tubes, and you can never get it all out again.
southend_styler
Re: paint stripping
« Reply #5 on: February 21, 2009, 07:14 PM »
If you end up going down the Nitromors route and end up having a lot of hassle with it, it'll probably be because your F+F are powdered (i.e. not sprayed) and powder is a bitch to remove. I suggest using Permatex Gasket Remover instead, for removing powder. You can get it on Ebay.  :daumenhoch:
Re: paint stripping
« Reply #6 on: February 21, 2009, 08:39 PM »
blimey sounds alot of greif!!!yes it is powdered so the latter sounds like it may be the best direction?anyone want to do it for me???!!!!!!! :LolLolLolLol:
Offline HARORIDER
Re: paint stripping
« Reply #7 on: February 21, 2009, 10:39 PM »
remember the gloves and mask when using Permatex Gasket Remover -this stuff can be lethal :daumenhoch:
Re: paint stripping
« Reply #8 on: February 22, 2009, 10:16 AM »
good advice,i remember having a bad experience with mr muscle once in a confined space,couldnt swallow for a week!!!!
lazyboy
Re: paint stripping
« Reply #9 on: February 22, 2009, 11:41 AM »
Mr Muscle,,,,,Must have being a big one .couldnt swallow for a week :LolLolLolLol:
Re: paint stripping
« Reply #10 on: February 22, 2009, 12:55 PM »
i knew someone would write that!!!! i thought it sounded wrong after id written it!!! :LolLolLolLol:
