975755
TattooedYorkie
September 22, 2024, 11:28 PM
GETTING OFF MUSHROOM GRIPS
Topic: GETTING OFF MUSHROOM GRIPS (Read 1322 times)
Swivel
Berm Worm
Ah feck it, go on then...
February 19, 2009, 10:02 AM »
Hi. Need some advice on getting these off my bars. They are jammed on their bigtime! I'm talking about the two tone coloured signature grips (blue/white). Be gutted if they get damaged but want to sell these bars but can't until they are off? Any ideas? I'm thinking heating them up with a hairdryer and going with the old chopstick and wd40 again etc...
Matt
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Re: GETTING OFF MUSHROOM GRIPS
February 19, 2009, 10:07 AM »
WD40.....use the red straw and poke it down as far as you can.....spray some in and work away
dan-dare
February 19, 2009, 10:10 AM »
You won't get the red straw down, those two tone grips are hard plastic.
An old spoke poked in, then spray the WD40.
sweetbeats
February 19, 2009, 10:18 AM »
Matt try a blowtorch...works everytime
snav69
February 19, 2009, 10:19 AM »
WD40 Matt , Just ease the grip out a bit then pump it full of the stuff then start twisting the grip back and forth and the WD works its way down the inside.I did it with my mushroom 2's
stidds
Site Supporter
My life is Radbmx
February 19, 2009, 10:26 AM »
Always use an old spoke, poke it down to make some room, spray wd-40 in & start moving the grip around. Repeat.
Swivel
Berm Worm
February 19, 2009, 10:41 AM »
Ta lads. They are very hard plastic indeed, so i'll find something suitable to wack in there and spray up with WD to ease them off
dodger
February 19, 2009, 06:57 PM »
also try soaking the grip area in boiling hot water to expand and soften the rubber and go to work on them just dry off the bars nicley after
pickle
Site Supporter
My life is Radbmx
February 19, 2009, 06:58 PM »
just cut em off Matt
HARORIDER
Look Back
February 19, 2009, 08:56 PM »
be careful on these if ya use boiling hot water as it softens the grip part up too much and they can split
best thing to do is once soaked roll the grip part off then work away on the white part
lazychubs
Founding Fathers
BMX Nerd
February 19, 2009, 09:50 PM »
airline ask rombloke works every time
ron burgundy
900 Air
Reply #11 on:
February 19, 2009, 11:03 PM »
Stanley blade and a rubbish bin
jT Racing
BMX Overlord
i like bikes. :/
Reply #12 on:
February 19, 2009, 11:10 PM »
Quote from: Lazychubs on February 19, 2009, 09:50 PM
used that on a pair of f1's and some ame tri's. worked a treat.
ding dong
Dark Diggler
Berm Worm
Reply #13 on:
Getting off mushrooms is not easy, I went to support groups for months but then I became resistent to them, so I took PCP to help get me off going to support groups-Bad move really. I have wandered round the O/S bmx scene since then, its nice and reasonably cheap by comparison.
Scampi Fries help with the cravings
COZZFATHER
Reply #14 on:
February 19, 2009, 11:25 PM »
i took some mushrooms off some c dubs today and i did what i always do, yok on the hole and pull the gripm hard to let the yok go down a bit then using my brute strength start twisting until it lets go and pops off, been doing this on bmx's and motorcrossers since bitd, never fails.
