975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:08 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  94 GT specs needed
Author Topic: 94 GT specs needed  (Read 16732 times)
Offline 20to26
94 GT specs needed
« on: February 11, 2009, 02:25 PM »
Hi, anybody got a 94 GT catalogue or tech specs for the complete bikes?
thanks
moley
Re: 94 GT specs needed
« Reply #1 on: February 11, 2009, 02:34 PM »
I have a 94 catalogue (or maybe 95)
What d'ya need?
Offline 20to26
« Reply #2 on: February 11, 2009, 04:45 PM »
Excellent Moley, thanks.
I need to know what components were used on the Team Edition series bike or at least the Pro Series bikes. I'm trying to build a factory spec build for this XLE frame:
moley
« Reply #3 on: February 11, 2009, 06:58 PM »
GT Stem (its slanted)
GT-6 Seat
GT Slight Layback Micro Adjust Seat post
GT/Profile Crank
GT DX Style Pedals
GT Overdrive Sprocket (Profile made)
Clear GT/Ame Grips
GT Mohawk Hubs
Weinmann 32 Hole Rims
GT AA Pro Tyres
Double Bolt GT SeatClamp
« Last Edit: February 11, 2009, 11:34 PM by moley »
moley
« Reply #4 on: February 11, 2009, 11:35 PM »
Heres some piccys to aid you!!
My Scanner isn't setup so this is the best I can do at the moment!!  :(
dodger
« Reply #5 on: February 11, 2009, 11:41 PM »
these things are lush i used to drool over them in my younger years.
will be a stunner if u can get it fully built.
good luck :)
moley
« Reply #6 on: February 11, 2009, 11:49 PM »
Most of the parts are on the Robinson Pro Team as well!!
I already have most of the parts except Clear GT/AME grips.   DC MX88 lever.
I have a load of GT Pedals (1/2" though) that you could probably swap the axles on!!
They are used but you could restore them (if ya can be arsed)
Offline kev-s
« Reply #7 on: February 12, 2009, 12:35 AM »
nice frame :daumenhoch: :daumenhoch:   im on the look out for one, just need to find someone with one who wants to swap it for a 1in s&m dirtbike
moley
« Reply #8 on: February 12, 2009, 12:36 AM »
I'd like one too but the Older Caliper Brake style!!  :daumenhoch:
« Reply #9 on: February 12, 2009, 08:11 AM »
i'd like one of those GT Profile chainwheels in black and silver!   :daumenhoch:
moley
« Reply #10 on: February 12, 2009, 08:31 AM »
They pop up now and again on US Ebay!!  :daumenhoch:
« Reply #11 on: February 12, 2009, 08:38 AM »
yeah i'll keep my eye open.....my lad's got one in blue on his retro performer  :daumenhoch:
« Reply #13 on: February 12, 2009, 08:43 AM »
nice!  there's a 1" red one on there as well which is fooking gorgeous!
moley
« Reply #14 on: February 12, 2009, 08:51 AM »
All the adverts show a Silver rather than a Red one!!  :(
But it does look lush!!  :)
« Reply #15 on: February 12, 2009, 08:53 AM »
sure does!  and those Dyno stems are dam good quality as well.....i've had 2 now and never let me down  :daumenhoch:
Offline 20to26
« Reply #17 on: February 12, 2009, 02:45 PM »
Moley you're a STAR!  :) That original bike is sweeter than I thought, and quite different to what I've started to collect.
I have the correct bars for starters.
Strangley I have a threaded fork?!? I see from the pic that's Aheadset. Mmmmm
I've also collected the incorrect Stem (mines very similar but for threaded 1" forks so it has the shaft & quill) and a different GT sprocket...
It shows you how valuable older resource material is. Thanks!
Does it mention the make of brake & headset?
moley
« Reply #18 on: February 12, 2009, 03:20 PM »
Your GT Sprocket might be okay!!
I think the older sprocket GT/Profile was used upto 1994
Brake lever were DC MX88 around 1992 but might have changed for the later models.
I haven't a clue about the brake (lugs) but earlier ones without cantis used a caliper and then Pitbulls before changing to canti mount.
This is the corresponding Robinson Team Model (Pro XL F+F)
It has all the same components as the GT Pro Series Team of the SAME year (This advert came from a 1993 BMX Plus) except Pedals (this robbo has caged DX sort of shape pedals).
So if you have this Sprocket then you might be okay for your 1994 build!!  :daumenhoch:
Your Threaded 1" Fork is NOT a problem if you want to use it.  You should be able to buy reducers so you can fit the smaller 1" cups!!
Offline 20to26
« Reply #19 on: February 12, 2009, 04:33 PM »
this is my 94 build stash so far (except the bar) - note the threaded headset/stem combo. The sprocket is a match to the Robo.
Got this stem on my '88 Pro which is the same as in the brochure but 1.1/8"
« Last Edit: February 12, 2009, 04:41 PM by 20to26 »
« Reply #20 on: February 13, 2009, 03:20 PM »
liking that second stem!  there's a red one on the bay at the moment (i think it's still there)  :-\
thought about it myself  :daumenhoch:
hooga1975
« Reply #21 on: February 13, 2009, 04:50 PM »
Moley, have you got a pic in the GT mag of the crusier?  I have a GT cruiser I am sure it is a 94 model
moley
« Reply #22 on: February 13, 2009, 06:06 PM »
Here ya go!!
moley
« Reply #23 on: February 16, 2009, 09:27 PM »
Right click the Picture below and save the .PDF file of the review to your PC
GT Pro Series Team from BMX Plus (Sept 1992)
Right click the Pictures below and save them to your PC.   The images are thumbnails of much bigger, better, higher resolution pictures.
GT Pro Series Team Advert BMX Plus (Jan 1994)
Dia-Compe MX88 - BMX Plus (Sept 1992)
Offline 20to26
« Reply #24 on: February 16, 2009, 11:00 PM »
those MX88 levers look a lot like some modern Vee brake levers.
