975755
TattooedYorkie
September 22, 2024, 06:24 AM
Crankset I'm thinking of running. Any comments or experiences?
Topic: Crankset I'm thinking of running. Any comments or experiences? (Read 507 times)
mykesbykes
February 06, 2009, 06:22 AM »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350150267097&ssPageName=MERC_VI_RCRX_Pr4_PcY_BIN_Stores_IT&refitem=120370232791&itemcount=4&refwidgetloc=active_view_item&usedrule1=CrossSell_LogicX&refwidgettype=cross_promot_widget&_trksid=p284.m184&_trkparms=algo%3DCRX%26its%3DS%252BI%252BSS%26itu%3DISS%252BUCI%252BSI%26otn%3D4
as long as its 118mm any american sealed BB should be okey?, but has anyone any suggestions as to which I should use, price is of course the driving factor here,
but I dont want to buy something that will blow up and grind bearings the day after I mount them...also are there chromoly cranks as light as aluminum? or would I
have to spend a small fortune for some tubular? Im 5'!0" and 155 pounds, and I tend to wreck aluminums, right at the bolt, I get horid squeeking sometimes, and
to end it, Ive restorted to cutting up my coke can and shaping a shim out of it by wraping it around the spindle end. works for awhile, but obiviously the problem only
gets worse. Maybe I should just stick to single pieces, as Ive rarely bent them, and they cant be that much heavier than a cheap chromoly 3pc right? well, thanks for
any ideas, m.
HEYWOOD BMX
Re: Crankset I'm thinking of running. Any comments or experiences?
February 06, 2009, 07:58 AM »
Probably light,but a chromo 3 pc or a decent 1pc crank will be much stronger and you`ll have less chance of stripping out the pedal thread.Square taper bbs have a tendency to work loose and squeak.Also at 5"10 would think 170s maybe a bit too short?
Last Edit: February 06, 2009, 09:16 AM by HEYWOOD BMX
mamadirt
February 06, 2009, 09:03 AM »
Chainring looks non-replaceable too.
Stronglight did make some decent mtb cranksets BITD though.
Last Edit: February 06, 2009, 09:06 AM by mamadirt
davevilla
February 06, 2009, 09:07 AM »
I'm not sure I go for this on a BMX - if price is the defining factor you should be able to pick up a decent used Sugino/Tioga OPC for £20-£30 on here or on the 'bay.
February 06, 2009, 12:50 PM »
170mm you will have trouble, even with 44/16 they feel spinny as!
