Check you alignment of your Wheel to your frame!!
You might want to stick the washer on the left or right side if it aligns your back wheel.
It also might help with alignment of your Sprocket to freewheel depending on which side you put your washer on!!
Tis only a small gap though, so most most people might not be bothered!!
