975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Scratches on Shimano DX pedals.
Author Topic: Scratches on Shimano DX pedals.  (Read 1274 times)
Offline southern andy
« on: February 01, 2009, 03:29 PM »
I have a set of 9/16 Shimano DX pedals that are in pretty good condition.
BUT..... there are scratches on both pedals which could do with a bit of care.  How and what is the best way to smooth them out. I'm hoping to leave them in silver.
many thanks.
Offline Bigfrawg
Re: Scratches on Shimano DX pedals.
« Reply #1 on: February 01, 2009, 03:32 PM »
use a sanding block and carefully follow the contours on the pedals
« Reply #2 on: February 01, 2009, 04:05 PM »
Do i use just standard sandpaper/wet&dry or do i go through the grades ???????
« Last Edit: February 01, 2009, 04:16 PM by Southern Andy »
Offline Bigfrawg
« Reply #3 on: February 01, 2009, 04:30 PM »
i used wet and dry , rough then progressively finer . takes a while but it's worth it
adeshere
« Reply #4 on: February 01, 2009, 09:36 PM »
thats not a scratch, thats good old ware !!!
steve Beech TA
« Reply #5 on: February 02, 2009, 05:15 AM »
I used some mini files on mine, they are about 15 notes for a selection of 8 or9 with different radius's on them from a flat one to a variety of curved one's to a variety of triangular one's. they help you keep the angles of the pedals crisp and the lines strait. Then go through the grades of wet and dry.
Here is a pic, i have a before somewere but cant find it, i will post it up later but this is almost half way through and as far as i have got. i am doing them bit by bit. its a bloody messy job though.
i will take a pick of the files later to.
hope this helps mate  :daumenhoch:
steve Beech TA
« Reply #6 on: February 02, 2009, 05:17 AM »
Yours should come up a treat as there no way bad as what mine where :daumenhoch:
« Reply #7 on: February 02, 2009, 12:31 PM »
Cheers Steve, they're in much better condition than the ones on my Quadangle.
I just wet and dryed those for ages and then had them painted. The paint covered the rest of the marks as i was too lazy to complete them.  :LolLolLolLol:
