975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 05:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cranks setup
Author Topic: Cranks setup  (Read 534 times)
coco
Cranks setup
« on: January 19, 2009, 10:04 PM »
Anyone got any tips for installing and setting up a crankset. My biggest problem is aligning the front and back sprockets. I dont want to tighten everything up, realise its not all aligned and then take it off to start again. Its a SINZ 3pc.
Thanks n that
moley
Re: Cranks setup
« Reply #1 on: January 19, 2009, 10:22 PM »
Leave the left hand crank arm off and just concentrate on your Sprocket arm.
Add the thin washers to move the Sprocket out and remove washers to move the sprocket in.
Its about as simple as that.
Use something straight to check the alignment or look from behind the rear wheel along the freewheel to the sprocket to see if its aligned.
If it looks about right the it should tighten up correctly.
The sprocket can't get any closer to the BB when its tightened due to the spacers/washers!
You could even try this without the spindle to calculate the correct number of washers but its far easier with the spindle in!
Just give it a go!
So long as you have a removal tool then it wont take long to remove the crank and add/remove washers if you cock it up!!  :daumenhoch:
HEYWOOD BMX
Re: Cranks setup
« Reply #2 on: January 20, 2009, 11:03 AM »
  You can also get spacers to go behind the freewheel/cassette if that needs bringing outwards...
coco
Re: Cranks setup
« Reply #3 on: January 20, 2009, 07:19 PM »
Thanks guys - thats useful stuff. Gonna give it a bash. :daumenhoch:
