975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  rust and corrosion removal
Author Topic: rust and corrosion removal  (Read 540 times)
sonic-1
« on: January 15, 2009, 01:19 AM »
well today i started rebuild on turbo for my car , called the recon Co as they surplyed parts to me was talkin to the guy who said i realy need to acid dip the center part to clean it out properly , he then gave me a very good little tip for de gungein n rust removal .................. use vinigar n scrub with a small stiff brush   :shocked: well i tryed it n dam me it works very well took all the rust off  and all the burnt on oil
now im not sure if it will damage chrome or not but it works for gettin rust off
(((sonic)))
Re: rust and corrosion removal
« Reply #1 on: January 15, 2009, 02:23 AM »
Vinegar works a treat, i had these hubs soaking in vinegar for 4 days before i polished them...
Before..
After...
Not quite finished yet,
Vinegar does work, use white vinegar throw in a few odds and ends and after a few days the vinegar is brown...  :buck2:
« Reply #2 on: January 15, 2009, 03:57 AM »
Citric Acid also works well or so I'm told, great for bare aluminium as removes the oxidation build up really well  :daumenhoch:
« Reply #3 on: January 15, 2009, 08:02 AM »
Check out the link I put up here , Vinegar is mentioned  :daumenhoch: .
http://www.radbmx.co.uk/forum/index.php'topic=73557.0
