975833 Posts in 138948 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 06, 2025, 09:50 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Quick Gearing question
Author Topic: Quick Gearing question  (Read 1177 times)
« on: January 14, 2009, 08:24 AM »
for a 12t rear cog, what should i run up front?  :daumenhoch:
Offline Stodgy
    • RADBMX Shop
Re: Quick Gearing question
« Reply #1 on: January 14, 2009, 08:28 AM »
33 me old sausage
« Reply #2 on: January 14, 2009, 08:40 AM »
okay......my next question then, as i've only got a 30 or a 28 front sprocket.......can i change the rear cog for any cog or does it have to be the specific type for the hub?
i know i'm  :uglystupid2:
Offline Stodgy
    • RADBMX Shop
« Reply #3 on: January 14, 2009, 08:48 AM »
Depends on the hub...some can be changed, and most suppliers give the option of different drivers.
« Reply #4 on: January 14, 2009, 09:00 AM »
Hmmmmm spoke to cyclesport and they inform me that they're a git to change......looks like i'll have to go a little bigger on the front then  :-\
JT71
« Reply #5 on: January 14, 2009, 09:16 AM »
you knob.
should have had a ltitle think about that before you bought it.
i run 28/10 but i understand 25/9 is quite common now.
obviously you want something that won't twat the coping too easily...that said BITD they were using 40t +  on ramps weren't they?
« Reply #6 on: January 14, 2009, 09:23 AM »
will 30-12 be really spinny then?
Offline Stodgy
    • RADBMX Shop
« Reply #7 on: January 14, 2009, 10:44 AM »
28/10 gives a ratio of 2.80
30/12 give a ratio of 2.50
on 20"x1.95" rear.
It will make in spinny...but what are you going to use it for? Shops?, Ramps? Parks?
Ramps n Parks it'll be fine...
CityBMXDAn
« Reply #8 on: January 14, 2009, 10:46 AM »
It will be a bit easier on the pedalling than a standard 44-16 feeling gearing. Anyway mate, i`m assuming you`re the guy that called me this morning? If you want to give me a quick call i think i might have a solution for you as i`ve just come across a few spare Prolite Drivers that we could fit a 10t on if that would be better for you?
« Last Edit: January 14, 2009, 12:45 PM by pickle »
« Reply #9 on: January 14, 2009, 12:45 PM »
Thanks Dan..........all sorted and well pleased  :daumenhoch:
« Reply #10 on: January 14, 2009, 01:00 PM »
on 20"x1.95" rear.
Stodgy, the ratio is the same, no matter what size wheel or tire.
The wheel/tire size will change the distance traveled per crank rev.  :daumenhoch:
« Reply #11 on: January 14, 2009, 01:15 PM »
i'm all sorted now anyways........10t driver and 28t sprocket.......top notch!   :daumenhoch:
fooking deal of the century!   :D
Offline Stodgy
    • RADBMX Shop
« Reply #12 on: January 14, 2009, 01:19 PM »
on 20"x1.95" rear.
I was going to go on and give distance travelled, hence the wheel size, but then couldn't be arsed. LOL. And it sounded a bit geeky.  ;D
« Reply #13 on: January 14, 2009, 01:29 PM »
would tyre pressure make any diference as well??    ;)
JT71
« Reply #14 on: January 14, 2009, 01:35 PM »
yes, it's really really really f***ing hard to pedal a bike with flat tyres.  :daumenhoch:
« Reply #15 on: January 14, 2009, 01:37 PM »
« Reply #16 on: January 14, 2009, 01:38 PM »
on 20"x1.95" rear.
Haha, I was going to say something about distance travellled too. I even typed it out but I deleted it.
We dont want anyone to think we are BMX Geeks, do we Stodgy  :-[ :-X
Offline Stodgy
    • RADBMX Shop
« Reply #17 on: January 14, 2009, 01:40 PM »
You know it Al.  :LolLolLolLol:
« Reply #18 on: January 14, 2009, 01:47 PM »
Niks dad Webbwood on here is the KING of gearings, crank length, tyre pressure, tyre sizes etc, could get Niks gearing to whithin 1/8th of a difference to change the bike and performance.
Geeky but it works :daumenhoch:
