975822 Posts in 138946 Topics by 6374 Members - Latest Member: Boults December 26, 2024, 03:53 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  angry and pissed off
Author Topic: angry and pissed off  (Read 3387 times)
Rabdul06
Re: angry and pissed off
« Reply #50 on: December 26, 2008, 08:51 PM »
Seeing as they're U/S anyway you have nothing to loose.
If you used heat on them you would need to get the shoulder very hot - bright red, to be able to straighten them up and put a bend back in. Youd have to push the leg up towards the steering tube as you did it to do this.
If you just heat the leg up and bend it open all you will do is put a kink in the shoulder as the tube collapsed.
A lit bit of TLC needed and you MAY get away with it. Definately hot over cold though.
The finish would need sorting after mind. Good luck mate.
kdubbmx
« Reply #51 on: December 26, 2008, 11:49 PM »
Seeing as the dropout is bent it points to them getting damaged in transit. IMO.
Offline Tefore
« Reply #52 on: December 27, 2008, 10:27 AM »
it's not very pleasing to the eye :crazy2: but it can be sorted. it cost you almost nothing so have a go. you can always replace the forks if you bungle the job.
very true. still a nice frame
Voodoocars
« Reply #53 on: December 27, 2008, 10:39 AM »
I live round the corner from Eamonn and just before he packed it for postage the pair of us jumped up and down on the forks for several minutes to bend them. Only jokin'.   ;) .Seriously, Eamonn is ok. Its certainly not intentional. I have seen some of his builds and sometimes I have had to point out that a saddle is on upside down.... :D
Offline jT Racing
  • i like bikes. :/
« Reply #54 on: December 27, 2008, 11:33 AM »
i wouldn't want to ride them if you put a lot of heat in them. it will alter the structure of the steel. not reccomended. Ok for a show bike, not for a rider.
ding dong
« Reply #55 on: December 27, 2008, 01:22 PM »
Might be worth having a word with our man that can, Sawzall to see if he can help out al all  :-\.
