975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Aero Zytec refurb
Author Topic: Aero Zytec refurb  (Read 1015 times)
Preston Pirate
Aero Zytec refurb
« on: January 31, 2006, 05:45 PM »
Anyone know where I can get some replacement bearings / axles for my Zytecs?
Ta
James
Re: Aero Zytec refurb
« Reply #1 on: January 31, 2006, 06:26 PM »
have a word with phil (oberonspacefruit)
i know he changed the seeled bearings in a set.
Donker
« Reply #2 on: January 31, 2006, 07:31 PM »
bearings from a front suzue sealed will fit, i have them in mine mate.
there are enough on the bay, just no rears which i need!
d14vd_h
« Reply #3 on: January 31, 2006, 08:26 PM »
pleaser correct me if im wrong
but the sealed bearing look reallyt similar to skateboard bearings
are these interchangeable?
ps how come they need a refurb, i thought these badboys were indestructible?
Donker
« Reply #4 on: January 31, 2006, 08:37 PM »
most stuff deteriorates with age   :o, especially if not re-greased on a mechanical part for example.
do you have to put oil in ur car engine? do bears shit in the woods  :LolLolLolLol:
when i removed the original bearings from mine, they were semi-sealed? ie: a seal on the outside but not on the inside.
but not sure if they were original.
« Reply #5 on: February 01, 2006, 08:27 AM »
you can get them from any decent bearings shop. 10mm by 9mm thick take the measuremens of the interal diameter , external diameter, and width. they are the same as mini moto berings too.
problem is, at 9 quid a pair, plus if your bearings are knackerd, your spindles may well be corroded, and they need to be a nice flush fit, otherwise they wobble, is it cheaper to buy a new set of zytecs...
« Reply #6 on: February 01, 2006, 10:45 AM »
i bought a NOS set for 20 quid plus post a few months back off the bay.
just buy a new set
Preston Pirate
« Reply #7 on: February 01, 2006, 01:33 PM »
Might keep an eye out for a cheap nos set and swap the bearings on to my blue ones then...
