975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 23, 2024, 07:34 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1inch threadless headset question
Author Topic: 1inch threadless headset question  (Read 706 times)
Glen
« on: December 23, 2008, 01:52 AM »
Will a 1 inch threadless headset cups and bearings only work with a 1 inch threaded fork using the current cone, washer and head lock??  I assume it would as its only the cups and bearings and the top bearing is a normal caged bearing.  I also assume Ill have to change the fork race to the new race to use the new needle lower bearing?
This YST threadless on a 1inch threaded fork:  http://cgi.ebay.co.uk/YST-1-threadless-headset-w-hanger-BLUE-ANODIZED_W0QQitemZ200291036354QQcmdZViewItemQQptZCycling_Parts_Accessories?hash=item200291036354&_trksid=p3286.m63.l1177
thanks
Re: 1inch threadless headset question
« Reply #1 on: December 23, 2008, 08:35 PM »
its the internal headset size you should double check first as alot of 1" arent actually the same.
ones for racers are about 2mm smaller.
telelogic
« Reply #2 on: December 24, 2008, 02:02 PM »
I just tried to have a Nikyo Oldschool Headset fitted to my 85 performer build,
the bloody cups are about 1mm too big :'(
really gutted. was told that it would fit any old school build!
and it was the only black headset I could find :-\
Now I feel like my whole build is compromised.
bloody gutted for christmas :(
telelogic
« Reply #3 on: December 24, 2008, 02:04 PM »
I know that doesn't really pertain to the thread,
but my shrinks phone was engaged and I had to tell someone ;)
« Reply #4 on: December 24, 2008, 02:09 PM »
telelogic that headset should fit might be tight but should fit.
glen a regular bmx headstock internal should be approx 32mm    a 1" threadless is  about 29.8mm so will flop about
telelogic
« Reply #5 on: December 24, 2008, 02:12 PM »
The guy at the shop that I had fit it said it was the wrong size ???
He seemed to know what he was talking about.
I'd obviously love it if he was wrong, if only for aesthetic reasons.
« Reply #6 on: December 24, 2008, 02:50 PM »
1 1/8 cups wont fit in a 1" frame   but you can fit 1" into a 1 !/8 frame  its a matter of fitting loose balls into a 1" cup and using the 1 1/8 top end set
confusing but been done alot.
