975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 09:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tight forkers
Author Topic: tight forkers  (Read 484 times)
brettnai
tight forkers
« on: December 21, 2008, 10:36 AM »
anyone got any tricks to prizing open forks so I can get a wheel on? its just that bit too narrow and I can't for love nor money get the wheel on even by pulling the forks apart.
tools and work space limited at the mo coz i'm at the girlfriends gaff
« Last Edit: December 21, 2008, 10:49 AM by brettnai »
brettnai
Re: tight forkers
« Reply #1 on: December 21, 2008, 10:50 AM »
anyone? i'm about 3 strains away from a hernia here  :LolLolLolLol:
Re: tight forkers
« Reply #2 on: December 21, 2008, 10:52 AM »
Sure you don't need one of those front spindles with the cut outs in?
brettnai
Re: tight forkers
« Reply #3 on: December 21, 2008, 10:55 AM »
I don't remember having one on there before. its a 10mm axle and 10mm dropout
Its just an Aero Reflex i'm putting together for a buddy of mine
If I need a different axle i'm screwed coz i gotta deliver this bike today
Re: tight forkers
« Reply #4 on: December 21, 2008, 11:04 AM »
i had the same problem on a pair of forks, had to go to my local LBS in the end, he had a tool that spread the forks, bit like a scissor jack
Re: tight forkers
« Reply #5 on: December 21, 2008, 11:19 AM »
right, i got ya.
ozone
Re: tight forkers
« Reply #6 on: December 21, 2008, 11:26 AM »
Sometimes there are washers in between the cones and the locknut - removing them would help.  Rear cones are often a bit shorter than cones for front wheels so using rear cones up front would also help.  Some locknuts are also much thicker than others so swapping fat for thin usually helps :daumenhoch:
brettnai
Re: tight forkers
« Reply #7 on: December 21, 2008, 11:28 AM »
I'VE DONE IT!!! F**K THAT HURT! just nearly lost a finger
