975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 02:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck in seatpost
Author Topic: Stuck in seatpost  (Read 1077 times)
fouronethreeoh!
Stuck in seatpost
« on: December 20, 2008, 07:34 PM »
Ive been wrestling all day with a seized in aluminium seatpost in my t1 barcode frame.
Jeez, ive tried everything, soaked it in lube for several days, frozen it in liquid nitrogen, had 10 tonnes on it in a press and the little blighter still wont shift. Ive buggrrd the post now anyway so it looks like im gonna have to drill it out.
I think the problem is that there is about eight inches of post in the frame  :(
I will not be beaten though  :knuppel2:
Re: Stuck in seatpost
« Reply #1 on: December 20, 2008, 08:11 PM »
costic soda will eat the alloy away until it vanishes ,dont inhale the fumes its bad
Offline jT Racing
  • i like bikes. :/
« Reply #2 on: December 20, 2008, 08:18 PM »
good thinking batman
ding dong
fouronethreeoh!
« Reply #3 on: December 20, 2008, 08:46 PM »
Yeah im liking that, good thinking batman.
  :daumenhoch:  :daumenhoch:
CoolHands
« Reply #4 on: December 21, 2008, 03:39 PM »
I think he means caustic soda (Sodium hydroxide) if you're searching for the stuff.
Offline jT Racing
  • i like bikes. :/
« Reply #5 on: December 21, 2008, 10:30 PM »
nice first post. your gonna be popular
ding dong
CoolHands
« Reply #6 on: December 22, 2008, 08:01 PM »
just thinking about this. How would you apply the caustic soda to dissolve the seat post? Presumably it'd be tricky to find a container big enough to suberge the whole frame.
Or could you block up the seatube (if it has a hole in the bottom) and try & fill it up with solution?
« Reply #7 on: December 22, 2008, 08:07 PM »
yep plug up the holes and fill the seat tube,its been done before.
you can get a container and just put the seat post part in tricky but it does disolve where it reaches.
trasher
« Reply #8 on: December 22, 2008, 10:04 PM »
how about the old toy arrow with the sucker on the end
push it down past the bottom of the  seat tube ,,,then pull it up slightly to form a seal
then pour in desired amount of caustic ,,,well you get the idea ,,,,
or should i get my coat  ::)
Offline stfc
« Reply #9 on: December 22, 2008, 10:15 PM »
depends on whether you are going to repaint the frame here but,  if you get a gas lamp/oxi and run it along the seat post tube on the frame  and then twist the post with a good pair of mole grips or similar it will come out, repeat obviously until it frees, alloy contracts and expands at a different rate to steel etc so that will do the trick, but will fook your paint, failing that soak it in diesel... failing that chuck it in a skip...
Juju
« Reply #10 on: December 22, 2008, 10:50 PM »
If its an ali frame, then anything with ammonia is meant to be good.
In roadie circles, this man was a legend and he virtually wrote the book on stuck seatposts. -
http://www.sheldonbrown.com/
and for you...  this link is the cats clit !
http://sheldonbrown.com/stuck-seatposts.html
all credit to the master of bike repair!
fouronethreeoh!
« Reply #11 on: December 23, 2008, 12:17 AM »
Was just trying to say how stuck in my post is.
Its well stuck, i froze it to -192c in liquid nitrogen to shrink it but it was still solid.
Had it up to 10 tonne in a press but still no movement.
So im going to try caustic soda to see if it will free it up a bit, its a steel frame so no probs there.
« Reply #12 on: December 23, 2008, 07:10 AM »
I wouldn't buy a frame with a seatpost stuck again done it twice and both times was a nightmare
with both combinations , Alloy frame and cromo post ,,,cromo frame and alloy post
Did the press , ammonia , weld another bar to it , to twist it out , ,soak in WD40 for days,,,,etc etc
tried em all
heat actually did work on the cromo framed one in the end
but the alloy framed one I had to get my brother in law engineer to drill down the seatpost tube vertically as far as possible so the old post was removed
He said never again ,,they had 3 holding the frame under a stand drill , so it wouldn't whizz 'em round the room  :LolLolLolLol:
Good luck
80sdave
« Reply #13 on: December 23, 2008, 01:03 PM »
Dude get yourself a handheld gas torch from homebase and gently heat the frame (seat tube section) keeping the flame constantly moving dont concentrate on one spot. We do it on bikes that come in to us for the same problem, might loose a decal or two and if you stay in one place to long you will risk bubbling the paint but usually takes 3-5 minutes tops then straight away with seatpost in vice get twisting using the frame as leverage rather than trying to turn the little seatpost and that should sort it.
Offline Rombloke
  • do one
« Reply #14 on: December 23, 2008, 03:02 PM »
caustic is the way to go on the chromo frame alloy post scenario...i think phil fruit has pics
Dave
haro, how do you do
Offline jT Racing
  • i like bikes. :/
« Reply #15 on: December 23, 2008, 11:00 PM »
i usually try to get ali posts knocked into the frame first to get some kind of movement before using the vice. cro-mo posts though are weaker and shouldn't be bashed. first you will need a piece of metal to place inside the end of the seatpost to prevent crushing in the vice then twist. Cro-mo in ali, no idea, never had one like that.
ding dong
« Reply #16 on: December 24, 2008, 11:39 AM »
I'd say drilling would get it out or a reamer  :daumenhoch:
