975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 09:15 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tap and dye
Author Topic: tap and dye  (Read 1330 times)
Glen
tap and dye
« on: December 17, 2008, 02:03 AM »
Does anyone have a standard 10mm 3/8 dye I could use to rethread my slightly stuffed 10mm rear axle?
I also need a 14mm tap to rethread a few stuffed 10mm - 14mm axle converters I damaged when trying to thread onto said stuffed 10mm axle!
Ill pay for postage from your address to mine and back to you again!  Thanks
Re: tap and dye
« Reply #1 on: December 17, 2008, 08:31 AM »
I probably have them but cannot check until I get home from work at 7pm.
Timmeh
Re: tap and dye
« Reply #2 on: December 17, 2008, 11:54 AM »
Is it not easier to replace the axles dude?
You'd have to take the axle out to cut the threads anyway, so whilst it's out, just replace it with new (upgraded?) axles?
Grease those balls!
lodge
Re: tap and dye
« Reply #3 on: December 17, 2008, 12:42 PM »
Standard tap/dyes wont be the same thread pitch as your axles, the axle will have a finer thread than a standard 10mm bolt for example.
J Rolla
Re: tap and dye
« Reply #4 on: December 17, 2008, 12:57 PM »
do you not have an old stainless steel nut that you could run over it with a few times?
Offline Peter J
  • I have issues
Re: tap and dye
« Reply #5 on: December 17, 2008, 02:28 PM »
Glen, where abouts do you live ?
Offline Peter J
  • I have issues
Re: tap and dye
« Reply #6 on: December 17, 2008, 02:57 PM »
Ok....I was going to say if your near Sheffield...you could have popped across to my brother-in-laws engineering company and we could have got it sorted.... ???
Offline Peter J
  • I have issues
Re: tap and dye
« Reply #7 on: December 17, 2008, 04:11 PM »
Offline BrianP
Re: tap and dye
« Reply #8 on: December 17, 2008, 09:23 PM »
Haven't seen any dies on there yet, but I bought a set of three 3/8x26tpi bicycle thread taps off ebay (uk) last week.
6 quid posted... dunno how good they are, but I'm only using them to thread a custom aluminium spacer.
Will see if I can find the link again.
Brian.
Offline jT Racing
  • i like bikes. :/
Re: tap and dye
« Reply #9 on: December 18, 2008, 07:08 AM »
Aldi, 14.99 fo a set of tap's and dies. they are spot on.
ding dong
Offline jT Racing
  • i like bikes. :/
Re: tap and dye
« Reply #10 on: December 18, 2008, 07:08 AM »
if your aldi has them :LolLolLolLol:
ding dong
Offline BrianP
Re: tap and dye
« Reply #11 on: December 18, 2008, 08:47 AM »
Brian.
Do you get the equavalent for 14mm axles?  Please post the link if you find it.  (should be under "won" in "my ebay")
got it:
http://cgi.ebay.co.uk/3-8-x-26-tpi-Cycle-Thread-taps-BSCY_W0QQitemZ370127835557QQihZ024QQcategoryZ121893QQtcZphotoQQcmdZViewItem
haven't had any luck yet for a 14mm one tho. still looking...
Brian.
