975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 04:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  profile box cranks spacer
Author Topic: profile box cranks spacer  (Read 579 times)
Glen
« on: December 15, 2008, 02:58 PM »
Ive attempted to install the new Profile retro box cranks into a 2008 Skyway TA, but Ive used both supplied tube spacers and theyre both too short.
Ive used a new sealed profile BB and the cups and bearings are installed flush and neatly.  When I install and fasten the arms down, you can hear the spacer moving inside the BB shell and im using the longer silver 53mm spacer.  Now what?  Alans longest are 53mm
fouronethreeoh!
Re: profile box cranks spacer
« Reply #1 on: December 15, 2008, 03:19 PM »
Could add one of the crank arm spacer/washer things inside the bottom bracket aswell as the tube.
Fiddly as hell i guess, i have made a new spacer before out of an old 7/8 inch seatpost, the profile spindle fits a treat.
Just hacksaw a length off and file down to required length.
fouronethreeoh!
« Reply #2 on: December 15, 2008, 03:35 PM »
Its probably more to do with the bb shell width of your frame which is leaving a gap when its all fitted.
Only takes a small gap and it wont tighten up properly, i had this problem with one of my bikes, making a longer tube cured it.
The tube ended up 0.5mm longer than a standard one.
