975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset help urgently required
Author Topic: headset help urgently required  (Read 800 times)
therock
« on: December 12, 2008, 02:38 PM »
got an ammaco 18" freestyle that im turning into a little torker pit bike , bought a 1" headset and its no were nears small enough to fit it . spent an hour filling the 1" but its still no were near . is there a smaller size than 1'
moley
Re: headset help urgently required
« Reply #1 on: December 12, 2008, 02:50 PM »
Measure the internal diameter of your Headtube
A BMX 1" normal cup size for a (22mm quill) is 32.7mm
Remember your Headtube diameter will be slighter lower than this.  32.7mm = 32.0mm or whatever so that your Cup stay in the head tube.
If its not a BMX 1" standard then it will be 32.2mm Cup diameter which will be a head tube diameter of less than 32mm
Raleigh also used the smaller sized cup diameters!!
Look here for a run down
http://www.sheldonbrown.com/headsets.html
moley
« Reply #2 on: December 12, 2008, 02:53 PM »
Remember BMX is NOT the Standard 1" size headset that all other 1" bikes use  e.g  Ladies bikes and Shopping bikes etc, etc.
The BMX standard is probably larger for strength reason (just a guess)
therock
« Reply #3 on: December 12, 2008, 03:26 PM »
mmmmmmm great so were the hell do i get a smaller thatn 1" headset
moley
« Reply #4 on: December 12, 2008, 03:34 PM »
A 1" road bike headset might do!!
And maybe some of the Burner Boys might know of where to get them.
Most Raleigh bikes would have used the smaller headset (Not the BMX's though, I think)
You'll have to do some searching on Ebay or internet and then email them to find out the cup size diameter!
What is the internal diameter measurement of your headtube?
PS.  Its still a 1" headset just different sized cups!!
« Reply #5 on: December 12, 2008, 03:36 PM »
mountain bikes are smaller in diameter.
post up a pic of the head tube, with a tape across it, and ill see what ive got.
therock
« Reply #6 on: December 12, 2008, 03:39 PM »
okidoke , ill get a pic tommorow , its well pist me off though , nothings ever straight forward  :-\
