975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 08:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spokes measuring help needed
Author Topic: spokes measuring help needed  (Read 1149 times)
« on: January 29, 2006, 11:31 AM »
i would like to no how to get the correct measurement for spokes ,i usually copy hub and match against one i havenew set of hubs and rim but can not match against any in stock.
Offline Steve P
Re: spokes measuring help needed
« Reply #1 on: January 29, 2006, 12:02 PM »
Try this link !!! CLICKETY CLICK !!!
If you're using 20" rims use:
 - 194mm spokes with lo-flange hubs
 - 184mm spokes with hi-flange hubs
Steve
« Reply #2 on: January 29, 2006, 03:19 PM »
so wot do 182mm fit then lol
as thats wot ive just got
Offline Steve P
« Reply #3 on: January 29, 2006, 03:42 PM »
182mm spokes should be OK to use with hi-flange hubs . . . the cross pattern will be a little tighter
You may need to use long spoke nipples . . . just to make sure . . . !!!
Build one side of a wheel first and make sure there is enough spoke slack to centralise the hub before you lace the other side
Hope this helps
Steve
