975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 04:12 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  HELP!!! skyway prob wheel went rigid, wont roll, NEED INSTANT FIX! pleasee.....
Author Topic: HELP!!! skyway prob wheel went rigid, wont roll, NEED INSTANT FIX! pleasee.....  (Read 885 times)
d14vd_h
ok guys just been attempting to fix my brothers front skyway
for some reason the wheel starte resisting and no turning smoothly once i got back home i started to try and fix, for some reason the axle is turning all the way round and the outside axle nuts are turning too,
so when i tighten them the wheel goes rigid!?
whats happened? am i missing a washer or are the lock nuts closest to the wheel too tight.
really could use ure help as i want to fix tonight!
Offline Waxintaxin
loosen your cones a bit
d14vd_h
done
what a nightmare of a job, had to get exact balance between cones and axlenuts tightness
done now never again,
cant think what caused it to go off balance in the first place
Offline ORB
you had the cones tight, but you never nipped the lock nuts up tight to the cones.
Piece of piss really ;)
12
