975825 Posts in 138946 Topics by 6376 Members - Latest Member: The Carrot Cruncher December 28, 2024, 04:40 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  WHAT ARE THE BEST NEW SCHOOL BRAKES??
Author Topic: WHAT ARE THE BEST NEW SCHOOL BRAKES??  (Read 1305 times)
Offline HARORIDER
« on: November 20, 2008, 08:19 PM »
sorry if this has been covered already :daumenhoch:
Re: WHAT ARE THE BEST NEW SCHOOL BRAKES??
« Reply #1 on: November 20, 2008, 08:25 PM »
it has been and its just listen read threads and articles and opinions
well i read and listened and listened some more,but after watching mike o'connell
riding with a very basic ad990 at about £10 the choice is yours.
a £100 pair not set up well against a dialled £20 set   it would choose the £20 set.
Offline HARORIDER
« Reply #2 on: November 20, 2008, 08:28 PM »
sound advice mate :daumenhoch:
jedi
« Reply #3 on: November 20, 2008, 08:53 PM »
the eclat new ones look nice in the flesh
JT71
« Reply #4 on: November 20, 2008, 08:55 PM »
but Hombres work for about £10
it's all about setting em up, sanding the blocks, getting good blocks, cleaning your rim, tweeking.
Jedi's front brake will have you over the bars, my Hombre, just stops me.  :daumenhoch:
« Reply #5 on: November 20, 2008, 09:59 PM »
hombre's are good. as people have said, its about the setting up. some 990's have poor grade alloy, and flex more though.
ive found primo e brake to be good, but evolvers are my fav.
Obbie
« Reply #6 on: November 23, 2008, 07:25 PM »
Dia compe 999 box u brake by far the best working , lightest and best value for money only at cyclesports tho at £30 each , angled and straight , every were else they are £50 and £45 . I wouldn't use anything else unless you don't want to spend that much , so go for the diacompe mil hombre or ad990 , be carefull tho if you have a frame with removable lugs as the canti type brake block setup won't fit and you will need a standard block set up (threaded post not canti post)
« Reply #7 on: November 23, 2008, 07:27 PM »
good tech tip that obbie   :daumenhoch:
lodge
« Reply #8 on: November 23, 2008, 07:38 PM »
Do you know if the AD999 can be run as a front brake Obbie? i Seen Cyclesport were doing them at that price but there web site only lists the angled version.
I seen one set up last week it was nice, very similar to a Fly.
« Reply #9 on: November 23, 2008, 07:44 PM »
they do a cs model and s ss model     so one will not be angled and usable on the front.
darkersomeday
« Reply #10 on: November 23, 2008, 08:44 PM »
ad999,
best brake on the market :daumenhoch:
Offline Rombloke
  • do one
« Reply #11 on: November 23, 2008, 09:19 PM »
ive had tektros working bang on, and hombres, never had any of the new fangled ones, fly etc, so cant comment on these, but as has been already said, i think a lot of it is in the set-up.
spend a score on a set of hombres, and fettle them, if they dont work, youve only lost twenty squids.
Dave
haro, how do you do
« Reply #12 on: November 23, 2008, 09:35 PM »
my half price fly brake works the nuts but so did me odd evolver once set up right
Offline kev-s
« Reply #13 on: November 24, 2008, 04:52 AM »
as already said its all in the set up, i run a fly brake on my new school bike and a ad990 on my mid school bike, both use the same make of pads and both are just as good as each other
JT71
« Reply #14 on: November 24, 2008, 07:39 AM »
the best answer to this thread would have been:
"you can put brakes on new school bikes?"   :shocked: :shocked: :shocked: :shocked:
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
but I stand by my original statement, Hombres, and I've just discovered a slic, but not the linear version, brake cable lets you get the front shorter with a tighter bend, you can't get the bend as short with a linear cable, and the shorter the better.
(thanks to S&M alex for this info, he's really flash though and runs most of his front in linear outer, then has a joining ferrule and uses non-linear outer for the bend)
« Reply #15 on: November 24, 2008, 07:56 AM »
have to say i've never seen the point of using a linear on the front as the whole point of them is that they don't bind up when spun (on the rear) so if you use one on the front where is the spinning?  they stay static and spin with the forks and bars.......so why spend twice the amount on a linear when a normal slick cable will get a smaller bend and work just as good?
oh and Hombre for me  :daumenhoch:
« Reply #16 on: November 24, 2008, 08:13 AM »
Linear cables are better than coiled outer cables because they dont compress as much, so you get a less "spongey" feel to the brake. They were first used on index gear cables to help keep the lever in sinc with the rear mech.
« Reply #17 on: November 24, 2008, 08:15 AM »
well that told me then  ;D
« Reply #18 on: November 24, 2008, 08:17 AM »
Every days a school day  ;)
« Reply #19 on: November 24, 2008, 08:20 AM »
you aint wrong mate.......in fact i'm off in a mo for a whole mornings training  :crazy2:
JT71
« Reply #20 on: November 24, 2008, 08:25 AM »
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
Rob is that work training or bike training?
« Reply #21 on: November 24, 2008, 08:30 AM »
work unfortunalety  >:(
poxy mandatory training all morning!   :crazy2:
« Reply #22 on: November 24, 2008, 03:46 PM »
AD990,always used it on my bike and has never let me down
« Reply #23 on: November 24, 2008, 04:24 PM »
evolver up front primo on rear
Offline Rombloke
  • do one
« Reply #24 on: November 24, 2008, 06:36 PM »
rich kid
haro, how do you do
