975755
TattooedYorkie
September 21, 2024, 03:36 PM
freewheel removal
Topic: freewheel removal (Read 602 times)
motomagII
freewheel removal
November 19, 2008, 03:56 PM »
right i removed a freewheel with borrowed tool .this tool had hole in it for the axle at 10mm .my other wheel has 14mm axle so do you buy removal tool for 14mm axles or does the axle need to be removed ?ps i dont know how to get the axle out on sealed new school we the people salt hub?
JT71
Re: freewheel removal
November 19, 2008, 04:19 PM »
if it's a sealed hub it should be easy just undo all the nuts and things and out it'll come.
failing that drill the hole in the tool ouy bigger, the person you borrowed the tool off probably won't notice.
CD17
Berm Worm
November 19, 2008, 05:00 PM »
Unless they read this
motomagII
November 19, 2008, 05:07 PM »
best send del message not to read this post lol
Del
Look Back
Re-living my youth!
November 19, 2008, 07:15 PM »
dont even think about it!
JT71
November 19, 2008, 07:23 PM »
ooops. busted.
meticulous
Berm Worm
November 20, 2008, 04:43 PM »
Quote from: Del on November 19, 2008, 07:15 PM
think he already has...
R.I.P O.M. Far short of the finish line...
freewheel removal
