975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 09:36 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff neck pots mod
Author Topic: Tuff neck pots mod  (Read 939 times)
Offline Glynnyboy
Tuff neck pots mod
« on: November 13, 2008, 06:55 AM »
I am wanting to use a tuf neck stem on my firebird and have the pots mod set up.At the moment it has a normal bolt. Is a conversion kit available, How easy or hard is it? Any help appreciated.
Offline phantom photon
Re: Tuff neck pots mod
« Reply #1 on: November 13, 2008, 07:54 AM »
Just have to swap the standard bolt for a hollow one - not sure how avaialble they are though  :-\
Offline Glynnyboy
« Reply #2 on: November 13, 2008, 04:47 PM »
Only just started looking and noticed yours and the one on db's kuwy. I am sure i saw something on ebay once just trawling through but i wasn't after one then. Just wondered if any one knew any info or could point me in the right direction :daumenhoch:
« Reply #3 on: November 13, 2008, 06:54 PM »
I think I have some ACS ones that will fit, you may have to drill your stem out a bit though as they are a bit wider  :)
Offline Glynnyboy
« Reply #4 on: November 14, 2008, 06:55 AM »
Thanks matey, i think i will try to do a bit more research into it 1st. I am nearly sure i have seen somewhere that tuf neck did a kit themselves. A bit more homework i think.
Phantom photons yours looks well cool. I have a black one in an old db stem from the late 80's early 90's , it looks a little like an acs . The one you have looks like a hollow bolt topped off with an axle nut. The way it fits with the tuf neck bolt looks cool. It must have been especially made because most pots bolts don't have a thread at the top aswell enableing you to do what seems to have been done on yours.
snav69
« Reply #5 on: November 14, 2008, 07:17 AM »
I fitted a Tuf Neck potts mod kit to my DK stem , I had had the kit for years and can't remember where it came from though  :-[
Stem is for sale on ebay  ::)
 :coolsmiley:
Offline Glynnyboy
« Reply #6 on: November 14, 2008, 07:49 AM »
So looking at yours the one on phantoms is the same, a tuf neck kit. When you put it on your dk did you have to drill out?
snav69
« Reply #7 on: November 14, 2008, 08:30 AM »
No drilling  ;)
« Reply #8 on: November 14, 2008, 11:18 PM »
 :coolsmiley:
I so want one of those early DK stems  :(.
snav69
« Reply #9 on: November 15, 2008, 10:29 AM »
I know mate  :'(
