975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 03:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Doofus question about potts modding a front brake...
Author Topic: Doofus question about potts modding a front brake...  (Read 475 times)
davevilla
« on: November 07, 2008, 07:20 PM »
Evening all
Been doing some work on one of my bikes today, changing a normal front brake set up to a potts mod with using a fs880 front brake caliper. Haven't actually done this before - I ususally stick to a normal brake setup.
I have used a rear brake cable due to needing extra length ( ;)) and this is my snag. I can't get any tension in the brake caliper, I've cut the brake cable sleeve down a bit and whilst the brake pulls, it merely grazes the wheel rim as opposed to stopping it. Do I need to lose more cable sleeve to get more cable to create more tension?
Here's a piccie to give you an idea of what I'm on about (I'm changing the tyres BTW)...
Many thanks
Re: Doofus question about potts modding a front brake...
« Reply #1 on: November 07, 2008, 07:25 PM »
has the cable got a kink or caught .  or is the caliper center nut been over tightened.
davevilla
« Reply #2 on: November 07, 2008, 07:32 PM »
Could be both?  I'll check tomorrow, thanks very much for the trouble shooting tips  :daumenhoch:
