975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 07:54 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  does the spider come off surgino 400 flites
Author Topic: does the spider come off surgino 400 flites  (Read 821 times)
« on: November 04, 2008, 05:31 PM »
just had mine re chromed and the chrome hasnt taken at the back of the arms, looks worse than before, and the chromers dont know what steel the spider is made of, any ideas?   sam
Offline double chevron
Re: does the spider come off surgino 400 flites
« Reply #1 on: November 04, 2008, 05:35 PM »
Nope mate, it doesn't come off.
Spider is alloy, btw.
« Reply #2 on: November 04, 2008, 05:58 PM »
dam! looks like they have ruined it then... :'(
« Reply #3 on: November 04, 2008, 06:19 PM »
Got pics ?
Or the address of another chromer ?  ;)
« Reply #4 on: November 04, 2008, 06:40 PM »
i know its difficult to make out properly, but the chromers said the solution just poors out of the nooks and cranies... :'(
thecrooch
« Reply #5 on: November 04, 2008, 06:41 PM »
as far as i know most chromers wont touch a pair of 400's as you cant seperate the spider from the arms and you cant dip the spider as you have obv. just found out...
sorry dude but i think you have done as much as you can.
« Last Edit: November 04, 2008, 06:56 PM by Crooch »
« Reply #6 on: November 04, 2008, 06:49 PM »
thanks! thought so, and thats what the chromer said, so ive just put them back on the bike... :daumenhoch:
Frosty
« Reply #7 on: November 04, 2008, 07:10 PM »
you're not alone, the spider is the difficult bit as mentioned but typically it is the part behind the arm that is worst affected like mine below but once on a bike doesn't stand out too much!
« Reply #8 on: November 04, 2008, 07:24 PM »
So how were these done BITD, were they done separately then assembled  :-\
« Reply #9 on: November 05, 2008, 11:19 AM »
I reckon so Chris, can't see how they would have done it otherwise  :-\.
Offline DIRTBIKER250F
  • Home sweet home
« Reply #10 on: November 05, 2008, 11:29 AM »
Can you not Hack the spider off and use spacers to apply a new disc ??? or something along them lines
Its been 2 years since i owned 400s so i cant remember the gubbins of the spider.
« Reply #11 on: November 05, 2008, 11:32 AM »
If I remember right the spider is pressed onto the crank arm with a folded ring (oohh err), you might be able to get a machinist to remove it but I reckon damage would occur to both crank arm and spider thereby rendering them expensive paper wieghts  :(.
Offline Jt
« Reply #12 on: November 05, 2008, 11:39 AM »
they are pressed on...
and frosty's cranks are the best rechromed one's ive seen...
radman got some done for me and they are ok, but as the spider is alloy, it's never be right...
just stand back another foot and forget about it, or buy some original chrome ones..
they are your only 2 real world options :daumenhoch:
