975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 07:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How in the name of Christ do u set caliper bakes correctly
Author Topic: How in the name of Christ do u set caliper bakes correctly  (Read 1227 times)
scary_leary
« on: January 24, 2006, 05:19 PM »
Mine always feel shite..
Can anyone give me a dickheads guide too caliper perfection.
Re: How in the name of Christ do u set caliper bakes correctly
« Reply #1 on: January 24, 2006, 05:29 PM »
what calipers are you running new or old school
« Reply #2 on: January 24, 2006, 05:41 PM »
if its old school dude, remove inner cable and grease it as you slide it back in the outer, use masking tape to hold calipers tight on your wheeland pull cable through the caliper as tight as you can and tighten, then pull brake lever as hard as you can a good few times, this will hopefully stretch any give in cable out, then undo the fixing bolt and pull cable as tight as you can again and pull lever as hard as poss, remove masking tape, if your wheel is straight the blocks should be clear of the rim and your brakes nice n flex free, it can take a good few rides before your blocks bed in, when they do, mask calipers back to rims and pull cble through again to minimise stretch as cable should be worn in. lots to do but well worth the effort :)
Offline Stodgy
    • RADBMX Shop
« Reply #3 on: January 24, 2006, 05:42 PM »
Get Fuzzynod to do 'em.
Sorted.
They have your fecking kidneys out.
Jazzchimp
« Reply #4 on: January 24, 2006, 05:53 PM »
I screw the adjuster all the way in to set cos the cable always stretches
If it's still not enough - take a block out before you tighten.
If it's still not enough - hit em with a lump hammer
scary_leary
« Reply #5 on: January 24, 2006, 06:45 PM »
Cheers everyone
i'll give my wire a good pull later!
Lee
