975755
TattooedYorkie
September 22, 2024, 05:41 PM
flight vs proline cranks
Topic: flight vs proline cranks (Read 931 times)
Glen
November 03, 2008, 12:37 PM »
So whats the difference between full wrap 401 flight and proline other than the wider indentation?
The prolines might have slightly bigger pinch bolts? Are the arm thinkness and BBs the same?
Seeing as 401s cost so much, prolines seem to be a good buy. Or are twin pinch flights better than prolines?
thanks
HEYWOOD BMX
Re: flight vs proline cranks
November 03, 2008, 12:45 PM »
Are you referring to the older Flights or the new ones? The newer have a twin-pinch bolt whereas the Prolines are single pinch.I don`t know if Prolines are available in the UK.I have some and they have been fine so far.
Stodgy
BMX Overlord
Prolines aren't old school - they are new school cranks.
The NS Twin-pinch flights are better than the prolines - lighter, stronger and nicer.
It depends what they are going on, if it's for an old school bike, go for a proper old school crank.
www.radbmxshop.co.uk
HEYWOOD BMX
November 03, 2008, 12:58 PM »
Pretty sure new school Flights are lighter/stronger than Prolines,also more expensive.
R Al
Rockwalk
November 03, 2008, 02:33 PM »
Prolines are a budget crank and are thicker and heavier than Flights old or new, but are pretty good for a rider and I've got some for sale if you're interested
R Al
Rockwalk
November 04, 2008, 04:26 PM »
Here ya go, what you see is what you get
No BB unfortunatley but these can be picked up anywhere as it is a 19mm spindle, looking for £45 posted LMK
Spen69
Site Supporter
Tail Whip
It was less than TWELVE parsecs.... .
November 05, 2008, 04:31 PM »
19mm sealed BB sets on gaybay for £13.99 BIN if you look under seller "angpatten357"
That's a cheap solution for a crank of this calibre fellas
Spen
