975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 01:46 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting a Shimano DX Lever
Author Topic: Fitting a Shimano DX Lever  (Read 730 times)
mr mclean
« on: October 31, 2008, 09:06 PM »
Hi All,
Got a Shimano DX rear lever to fit - but can't figure out how to route the cable on it!!! :crazy2:
Can anyone help? With a pic if possible...  :)
Ian
Re: Fitting a Shimano DX Lever
« Reply #1 on: November 01, 2008, 02:15 AM »
Ian, pull the inner cable through a bit so you have about 4/5" of cable with the ferrul (barrel) ready, push it inside the lever, then when you move the handle you will see a cable stop, hook the barrel over that, pull the outer cable tight onto the plastic guide, keep it all tight and tighten up the caliper, its quite straight forward, If you still dont get it I will try and take some pics for ya tomorrow :daumenhoch:
mr mclean
« Reply #2 on: November 01, 2008, 01:39 PM »
cheers ratty,
sorted it - i wouldn't have figured it out without the pointer!!
ian
