Hi lads,
After putting Wanted Ads and something in the Tech Section I have decided to post here because it might be something you mid schoolers might know about.
I have a mid 90's F+F.
It has 1" threaded Forks and has a Headtube diameter of 34mm.
Normal sized Headtube diameters suitable for 1" threaded forks are 32.7.
BITD these Headtubes were called Oversized. They eventually went on to be the the normal headtube to fit 1 1/8" threadless forks (I think)
Someone in the mid 90's must have made Headsets to fit the large diameter headtubes (34mm Cups) instead of the normal 32.7 cups.
I know this because I have two of these headsets. One is on my '95 Auburn and it is worn and I want to replace it. The other is on my early 90's Haro Group One.
Apart from the cup sizes. The internals of these 2 different cup sized headset (bearings, races, locking washers and Top Nut) are interchangeable. It's just the cup sizes are bigger so they fit the larger headtube.
So to recap. I am after a 1 1/8" sized headset that is threaded for use with 1" forks
or a 1" threaded headset with 34mm Cups NOT the 32.7mm normal sized cups.
Does anyone know where I can buy one of these headsets or have any information that might help me?
Thanks
PS. I hope this makes sense!!
![Huh ???](http://www.radbmx.co.uk/forum/Smileys/smilies/huh.gif)
