975760
TattooedYorkie
September 29, 2024, 01:25 PM
Removing the factory paint from alloy frames.
Topic: Removing the factory paint from alloy frames. (Read 742 times)
revcore
January 23, 2006, 04:05 AM »
I was wondering if anyone here has successfully removed the factory paint from an alloy frame? If so how was it done and what did you use?
Sanmarcopizza
Re: Removing the factory paint from alloy frames.
January 23, 2006, 07:30 AM »
If it's paint then I guess paint stripper would do the job.
January 23, 2006, 08:04 AM »
i just stripped my pk ripper frame using nitromors
underneath the paint was a yellow etch primer - like a yellow clearcoat over the alloy
fetch that off with wire wool (fine grade) and soapy water
sam hudson
January 23, 2006, 10:25 AM »
I had my Ripper bead blasted.No hassle for me and just £20.
