975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 09:32 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1" Threaded Headset Cup Sizes. Normal & Oversized
Author Topic: 1" Threaded Headset Cup Sizes. Normal & Oversized  (Read 1102 times)
moley
« on: October 22, 2008, 06:33 PM »
My Auburn has a slightly larger Headtube diameter than my other bmx's (oversized)
My early 90's Haro Group One also has a larger Headtube diameter too.
A normal 1" headset cannot be used because the Cups just fall out of the headtube (too loose).
The Auburn came with 1" threaded Forks and a Headset installed.  I measured the cup diameter and the Auburn's Headtube diameter and they are approx 34mm.   (Headtube being slightly smaller than the Cup so it wedges in)
A normal bog standard 1" headset (Tioga Beartrap 2, YST and GT Pro Series) cup diameter are approx 32.5mm in diameter.
The Auburn Headset internals are in a shitty state and so are the cups.  So I would like to replace the lot of them.
All the internals from a normal headset fit into the Larger diameter Headset cups.
Is the 34mm Headset cup diameter classed as a 1 1/8" Threaded headset (suitable for 1" forks/quill)
Does anybody understand this?
I need to know what headset to buy that :-
1.  Will fit my Auburn the the Oversized headtube (34mm)
2.  Will fit my Auburn 1" thread forks.
Any help would be appreciated!!
Cheers!  :daumenhoch:
HEYWOOD BMX
Re: 1" Threaded Headset Cup Sizes. Normal & Oversized
« Reply #1 on: October 22, 2008, 06:49 PM »
 Not much help,but I`ve just measured a Cane Creek 1 1/8 headset cup & that shows as 34mm diameter???
moley
« Reply #2 on: October 22, 2008, 06:59 PM »
I have come to that conclusion myself!!
I need to find a threaded headset that fits 1" forks but 1 1/8" head tube!!  :daumenhoch:
dazza
« Reply #3 on: October 23, 2008, 01:26 PM »
dont know, iknow you can get internal 1" aheadset with 34mm outer semi / fully  intergrated . try fsa site.
thecrooch
« Reply #4 on: October 23, 2008, 01:27 PM »
moley have a look on your other thread....
