976202 Posts in 138987 Topics by 6419 Members - Latest Member: BMXBoyBrookie March 19, 2026, 11:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  3 piece crank.Dust caps do u need em ?
Author Topic: 3 piece crank.Dust caps do u need em ?  (Read 2219 times)
sam hudson
« on: January 22, 2006, 01:27 PM »
Ok,my crank arm keeps working its way off the crank shaft.I havent put the dust caps on the ends of the shaft because i havent got a big enough allen key.Is this why the arm is working its way off?? (havent had much experience with 3 pieces...as you can tell).
I thought that they were just there to keep cack out of the shaft end.(this sounds disgusting).
I keep tightening the arm bolts up,but off it wobbles after a while on the track.
Offline jT Racing
  • i like bikes. :/
Re: 3 piece crank.Dust caps do u need em ?
« Reply #1 on: January 22, 2006, 02:58 PM »
??? you should have bolts holding your crank arms on. dust caps cover the bolt ends. This will be why they fall of.
ding dong
sam hudson
« Reply #2 on: January 22, 2006, 04:02 PM »
Ta,i suspected as much.I'll have to buy a big Allen key now. :-\
Offline Rombloke
  • do one
« Reply #3 on: January 22, 2006, 04:32 PM »
well if you keep riding with em coming loose you'll be buying new cranks....get a allen key, much cheaper
Dave
haro, how do you do
sam hudson
« Reply #4 on: January 22, 2006, 07:57 PM »
 :2funny:
