975829 Posts in 138947 Topics by 6376 Members - Latest Member: The Carrot Cruncher January 01, 2025, 04:16 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Rear wheel help!!
Author Topic: Rear wheel help!!  (Read 1036 times)
markatkins
Rear wheel help!!
« on: October 01, 2008, 12:27 PM »
I ride a We The People Beyond and find that the cassette hub is a piece of shite(it keeps bloody slipping),the wheel in general does not feel that great.
Riding vert i feel it flexes and slows me down although i have 115psi + the spokes are tight.Had enough of this wheel so im after something that wont flex and the hub wont slip.Even thinking about going for a 48 as not bothered about the weight issue.
Anyone rec a good complete wheel to buy?Im told you have to pay around £150+ for a decent wheel?Was'nt looking to pay that much but guess ill have to if it will solve the problem,
Cheers.
HEYWOOD BMX
Re: Rear wheel help!!
« Reply #2 on: October 01, 2008, 12:50 PM »
 Looked everywhere and seems that cassette hubs are pricey things.You should be able to get a complete wheel for under £150 though-Alans have a complete Odyssey wheel for £140.I know people who probably have every brand of cassette hub between them,and they all have differing opinions on each brand.Good quality spokes and a good wheelbuilder can also make a difference.Sorry I`m not much help,but I`m sure people on here will be able to give you a heads up on what to buy/avoid.
HEYWOOD BMX
JT71
« Reply #4 on: October 01, 2008, 01:05 PM »
ody
Hazard rim with cassette hub.
Bushwacked
« Reply #5 on: October 01, 2008, 01:13 PM »
Mark - is the chain tight?
I had a similar problem with chain slipping and the chain wasn't tight enough - it has either stretched or hadn't put the wheel back in properly.
Flexing in the wheel just means you need to stop hammering it so hard!!! :2funny:
subversion
« Reply #6 on: October 01, 2008, 01:54 PM »
Defo go the 48 route Mark :daumenhoch:
Offline kev-s
« Reply #7 on: October 01, 2008, 02:08 PM »
dont bother with the odd cassette they also skip and if u run ur chain tight they end up blowing the driver bearings, wait a few months (for the 48 hole, 36 hole will be sooner) for the new gsport hub, this uses needle bearings in the driver so u can run a tight chain without the bearings blowing up and has been designed to eliminate skipping and can be used for lhd and rhd with no other parts needed
spec
» 3 oversize pawls running in low-drag pivot cavities.
» 3 independent long-travel springs.
» Spring and pawl retention system ensures optimum alignment of pawls and drive ring, and keeps the hardware securely in place during routine maintenance.
» Oversize ratchet ring with square tooth profile for easy left/right drive switching.
» 20mm, hollow, helicoiled axles in steel (14mm bolts) or aluminum (3/8” bolts). All bolts feature a 17mm hex-head and 6mm Allen slot.
» 10 tooth chromoly drivers with a unique needle-roller and plain-location bearing arrangement for unsurpassed durability.
» 2 oversized cartridge bearings in the hub shell.
» Threadless, press-on axle collars.
» All hubs work LHD or RHD “out of the box” without special parts or complicated modifications.
Lifetime warranty on steel axles.
» 1lb 3.9oz
full details and answers from george himself here
http://www.bikeguide.org/forums/showthread.php't=89940&page=21
