975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 12:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SODA BLASTING FOR FRAMES AND FORKS
Author Topic: SODA BLASTING FOR FRAMES AND FORKS  (Read 1122 times)
trasher
« on: September 22, 2008, 07:48 PM »
hello guys , don't know if this has been covered before ,,,
but has anybody ever had there frame and forks soda blasted (with backing soda )
its serposed to be less aggressive on the metal ,without altering the surface profile
leaving it nice and smooth like the day it was made ,and leaving a fine dust covering protecting it from surface rust
for a good few weeks before you get your top coat done ,,and its eco friendly ,and you can also make a cake with whats left
so if anyones had it done ,what was the finish like ,and how much was it ,and where did you get it done  :daumenhoch:
cheers
glen
« Last Edit: September 22, 2008, 08:03 PM by trasher »
Offline superbikedan
Re: SODA BLASTING FOR FRAMES AND FORKS
« Reply #1 on: September 22, 2008, 11:13 PM »
tbh mate you can have your frame blasted with anything you'd like,
it's all about high pressure, even water can strip your frame and cut it in half
if you want :)
HEYWOOD BMX
« Reply #2 on: September 23, 2008, 08:33 PM »
 :) Would the fine dust covering react with paint/powder or chrome plate?
« Reply #3 on: September 23, 2008, 08:45 PM »
i wouldn't of thought so, deosnt matter how your frame is stripped, any decent painter will
re prep your frame prior to painting :daumenhoch:
trasher
« Reply #4 on: September 23, 2008, 09:38 PM »
dan is right ,the dust would stay on untill it goes to the finishes
dan you seem to be the man on here for finishing coats ,i know what you are saying about
removing paint with anything ,,even water ,with the right amount of pressure ,,it just seems that this soda blasting is less harsh on the frame
leaving a nice smooth finish ,giving a better prep for the final coat ,,theres even a clip on youtube  soda blasting a coke can
now to be able to blast a coke can and not damage the can ,must be good ,,as you probally know ,if you tried to blast it with
a conventional blaster it would rip the shite out of the can
just seems like a nice way to prep your frame to me
glen
HEYWOOD BMX
« Reply #5 on: September 23, 2008, 10:29 PM »
 :) Cheers fellas-not trying to be negative,just wanted to know :daumenhoch:
« Reply #6 on: September 23, 2008, 10:38 PM »
glen
glen, normal paint stripper will be the smoothest way you can strip a bike, any blasting no matter how smooth will
leave a texture on the metal, the best way is good ole stripper then 400 grit, your frame will come out as smooth
as a babbas bum as long as you get someone decent to paint it  ;)  trust me on this :daumenhoch:
trasher
« Reply #7 on: September 24, 2008, 10:28 PM »
glen
iv stripped it the good old fashioned way mate , abit of nitromores does the job ,,ill be in touch if i decide to get a coloured finish
i fancy chrome at the mo , but it can be a bit expensive
« Reply #8 on: September 24, 2008, 11:02 PM »
kool mate, was it easy to strip?  i'm always here to help if you don't want to go chrome :)
trasher
« Reply #9 on: September 24, 2008, 11:16 PM »
piece of pish ,ill be in touch if i want a color finish mate ,,i had my last frame powdered locally and it wasnt that good
some fish eyeing ,but it did only cost £30 and its a rider , but i want a better finish next time  :daumenhoch:
« Reply #10 on: September 24, 2008, 11:23 PM »
here this all the time about bad paint jobs, my starting price is not much more and it will come out good ;)
« Reply #11 on: September 25, 2008, 01:57 AM »
Dan, that's a down right lie there's not any frame you do "will come out good".  They all come out FANFOOKINGTASTIC  :LolLolLolLol:
bof
« Reply #12 on: September 25, 2008, 07:08 AM »
I have had an aluminium  frame soda blasted and it came out like new, The dust just washed off prior to having it powdered  :)
fouronethreeoh!
« Reply #13 on: September 25, 2008, 07:53 AM »
Just thought i'd chip in a little nugget of info
we paint strip aluminium aircraft parts with crushed walnut shells, they break down before doing any damage to the alloy or anodising.
