975804
V6 DOW
November 22, 2024, 11:37 PM
Tuff neck stem problem....
Topic: Tuff neck stem problem.... (Read 4350 times)
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
August 03, 2005, 05:23 PM »
i've put my Tuff neck on the Torker and there is about a 6-7 mil gap between the headset and the bottom of the stem as if the shaft on the stem is too long for the forks. Is there spacers/ washers or something i can use for 1" headsets?
Does anyone know if i use the tange lock might that take up the difference being that much bigger than the basic nut?
Cheers.
Last Edit: August 03, 2005, 05:26 PM by Bob_Acid
stuntmaster
540 Air
Re: Tuff neck stem problem....
August 03, 2005, 05:45 PM »
you sure the old stem bolt is not stuck in stem ,i had that on a skyway once also have had this on a few forks ie as the stem get lower in shaft the stem stops and does not go down anymore .it`s the forks that have the problem ie shaft gets smaller as the stem goes in normally where they weld the legs on .try this and that will tell you if forks are the problem and not stem.
i can`t see a way of fixing this only cut down the stem shaft so it`s not as long but mmm not a tuf neck .
no1stuntmaster on instagram
Bob_Acid
Team Admin
BMX Overlord
It's Bronked
August 03, 2005, 06:01 PM »
i think it is the forks paul.
stuntmaster
540 Air
August 03, 2005, 06:17 PM »
my old 80 mongoose had that problem ,i had to cut shaft down on stem to fix .
Rombloke
Team Owner
My life is Radbmx
do one
August 03, 2005, 06:33 PM »
shims from ots bob...under or on top of the lock nut....prob a few pennies each
dave
haro, how do you do
Sanmarcopizza
August 03, 2005, 07:25 PM »
I have had worse problems with a number os stems of the Pro Neck, Tuff Neck, DK variety in redline frames. They sit about an inch high. As mentioned below, it's the forks that taper inside.
Waxintaxin
Team Owner
Cherry Picker
August 03, 2005, 08:05 PM »
They squeek all the way down anyway
ORB
Founding Fathers
My life is Radbmx
Posts: I am a geek!!
August 03, 2005, 08:37 PM »
spinmaster
August 05, 2005, 09:34 AM »
was that drawn in photoshop orb?
Rombloke
Team Owner
My life is Radbmx
do one
August 08, 2005, 06:01 PM »
no jim...its a real photo on black and white film?
Dave
haro, how do you do
spinmaster
August 08, 2005, 06:05 PM »
taken using a night vision lense?
Rombloke
Team Owner
My life is Radbmx
do one
Reply #11 on:
August 08, 2005, 06:37 PM »
without a doubt!!!!
haro, how do you do
