975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 02:55 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  tange 320 (how do i fit this bugger)same as lp125
Author Topic: tange 320 (how do i fit this bugger)same as lp125  (Read 338 times)
STUMPYLEE
« on: September 21, 2008, 02:04 PM »
not sure if i am doing this right
1. in what order do i fit this
2. do i have to knock it into the frame to fit i'm sure it is the right size but it is a bit tight (bit like knocking the bottom bracket cups in)
Thanks for any help but i don't want to knock bits in then find out that i've do it all wrong i've only fitted the cheaper types before  :daumenhoch:
« Last Edit: September 21, 2008, 02:41 PM by STUMPYLEE »
Offline jT Racing
  • i like bikes. :/
Re: tange 320 (how do i fit this bugger)same as lp125
« Reply #1 on: September 21, 2008, 02:47 PM »
race bearing cup cup bearing race washer nut
 knock the race come cup in the top of headtube(like the one on the forks only has a flange with holes in it unerneath.
fit the race over the forks, knock the bottom cup(thing with the sticker on) in the headtube put bearing on race over forks insert  forks into cup through headtube. put bearing over forks onto race, screw on cover(bit with sticker on) put on washer screw on locknut. done.
ding dong
