975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 06:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fitting ball race cups?
Author Topic: Fitting ball race cups?  (Read 518 times)
beaglepopper
« on: September 17, 2008, 11:33 PM »
Is there a trick to the trade? or am i better off going to my local bike shop to press them in?
« Last Edit: September 18, 2008, 12:16 AM by beaglepopper »
Re: Fitting ball race cups?
« Reply #1 on: September 18, 2008, 05:30 AM »
If only one set LBS, if you've a few to do buy yourself a bearing press or make one up using a long and wide diameter nut and bolt (c. 7 inches long) and a few very large washers  :daumenhoch:.
toys19
« Reply #2 on: September 18, 2008, 06:34 AM »
When I was a teenager I used to mack these in using a hammer and a bit of hardwood, never had any problems. Nowadays I use a home made press as per MartyC's recommendation. You can get all you need from B&Q, I use 2 wide flat plates,(which were some cheap angle brackets from b&q) then you can do BB races too. total cost about a fiver.
beaglepopper
« Reply #3 on: September 19, 2008, 07:51 PM »
I went to my local bike shop and they had never come across a bike with push in cups!!! They are supposed to be the best bike mechanics around my area! My neighbour made me a homemade press at work and they went in a treat  :)
Offline phantom photon
« Reply #4 on: September 19, 2008, 09:10 PM »
Large hammer and piece of wood - just done a BB and headset about 30 mins ago with no problem  :daumenhoch:
