975768 Posts in 138935 Topics by 6360 Members - Latest Member: TattooedYorkie October 05, 2024, 11:23 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  new school brakes
Author Topic: new school brakes  (Read 1632 times)
danlightening
new school brakes
« on: September 06, 2008, 06:36 PM »
Hi all, just fitting my 1st new school rear brake and could do with some advice. I have a dc hombre going on a sunday wave. Could someone talk me through the order in which to do things with cable fitting etc. Only ever done old school before.
cheers
Dan
JT71
Re: new school brakes
« Reply #1 on: September 06, 2008, 07:32 PM »
just whack it all on.
but some wise advice i got from twobobrob
don't mix up the springs, they are different colours for a reason.
only put 1/4 turn tension on each spring.
then it's just tweaking. trust me it's quite easy.
Offline josh_spratty
« Reply #2 on: September 06, 2008, 07:34 PM »
i agrre twobobrob gave me the guide to fit one and had it done in 10 minutes easy-as:)
Stella Dave
« Reply #3 on: September 07, 2008, 03:27 PM »
I had to tighten more than that so they didn't rub!
I have DiaTech Hombre, it's really good
bmxer4ever
« Reply #4 on: September 07, 2008, 04:01 PM »
The springs tension in different directions, one for the left hand lug, one for the right - it's easy to figure it out when you look at them. Overtightening will bend the springs and you'll need new ones, so take it easy at first. Make sure you put a little grease on the bolts, and between the washers, it'll help the brake arms swivel smoothly.
G
danlightening
« Reply #5 on: September 09, 2008, 01:11 PM »
Ok so I am probably totally thick :idiot2: but I have done all of the above and the caliper that is sprung to sit against the wheel rim is doing exactly that. My instinct tells me that the curved cable guide needs to be clamped onto the cable when you have set the calipers in the correct position but I am assuming that it is supposed be able to slide. Anybody?
subversion
« Reply #6 on: September 09, 2008, 02:09 PM »
The spring tesion should increase as the block gets nearer the rim. If they are clamped to the rim you have the springs in the wrong way :daumenhoch:
Spring tension is the last thing you do when you set up a U brake ;) I set up mine without springs in to allign blocks & set cable lengths etc...
bmxer4ever
« Reply #7 on: September 09, 2008, 10:01 PM »
They should be sprung to pull AWAY from the rim.
danlightening
« Reply #8 on: September 10, 2008, 09:25 AM »
Ahh, so I have a problem here as whatever way I seem to put the springs, one caliper is sprung to pull away from the rim and the other to pull towards  :-\
subversion
« Reply #9 on: September 10, 2008, 01:39 PM »
Are the springs 'curled' the same way when you compare them?
danlightening
« Reply #10 on: September 13, 2008, 04:55 PM »
Finally sussed them ;D. see the bike in the show your rides section.
bmxer4ever
« Reply #11 on: September 13, 2008, 10:33 PM »
Thank gawd for that!  :LolLolLolLol:
