975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 10:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bleach has fooked my alloy hub Tuff's....
Author Topic: Bleach has fooked my alloy hub Tuff's....  (Read 3292 times)
Re: Bleach has fooked my alloy hub Tuff's....
« Reply #25 on: October 25, 2008, 08:39 PM »
Keep going Martin , it looks as though they'll come back  :daumenhoch:
Offline funkyfresh
« Reply #26 on: October 26, 2008, 02:39 PM »
i think i'll carry on with a scourer then? the pitting need smoothing out more...
BTW,
if i manage to lay my hands on some replacemnt flanges, has anyone had them re-riveted, rather than using bolts?
or i was wondering about using bolts, but with some sort of cap to cover the bolt head and nut? did a qucik search on the forums, but no joy?
My mate works for a machineing company..he might be persuded to re-make some rivets for me, if there is someone who can actually do the riveting part?
fouronethreeoh!
« Reply #27 on: October 26, 2008, 05:33 PM »
Theoretically riveting is just hitting it with a hammer.
Could be done fairly easily i should think, if your mate could knock up some more rivets.
Keep an eye out on ebay for replacement flanges, they do crop up.
trasher
« Reply #28 on: October 26, 2008, 07:36 PM »
mate keep with the wet and dry ,through the grades then some autosol ,,believe me i know its mind numbing
but its just took me six hours a wheel to rub down some tuffs with the wet and dry ,but the outcome is priceless
my last resort would be to replace the hubs ,,,id sooner fill the pitting and spray with some enamle  silver spray  :daumenhoch:
all the best with the outcome dude  :)
Offline billstup
« Reply #29 on: October 26, 2008, 08:35 PM »
I wouldn`t worry too much about the freewheel side, just put an 18t freewheel on like was mentioned earlier in the thread and it should cover the flange anyway  :daumenhoch:
« Reply #30 on: October 27, 2008, 11:26 AM »
18t will cover it easy, 17t shimano in nice shiny silver will do though.
I'd agree with Joe on the freewheel solution. The absolute last thing you want to do is drill them out as the value plumets like a stone mate, so keep them original. I wouldn't go as far an 18T though as it will be unridable (unless they're going on a show pony)
What freewheel did you take off? I'm asking as I discovered one of my set arrived with a silver 17T Shimano on them. I'll happily send it to you to try it and if you think it covers enough for you to be happy with them. You can send me a 16T replacement of similar condition - not a "non-branded" one if you get what I mean though :daumenhoch:
If it helps, just let me know fella.
Spen
Offline funkyfresh
« Reply #31 on: October 27, 2008, 03:58 PM »
Spen,
thats very kind of you...I have a NOS 16t Shimano freewheel that came of the wheels, if you want to trade?
i'm not sure how much bigger the 17t will be? I just measured the distance, tooth tip to tooth tip across the widest part, and its 71mm...
ta
Martin
Offline funkyfresh
« Reply #32 on: October 27, 2008, 04:04 PM »
the side that is OK, i.e. quite polished, would look better if it had the "satin" effect that the normal flanges have, if was being picky.
can that be achieved somehow?
« Reply #33 on: October 27, 2008, 04:09 PM »
A type of light scouring pad my dull it down ok  ;) .
Offline funkyfresh
« Reply #34 on: October 27, 2008, 04:12 PM »
i think i might find some bit of alloy to practice on 1st then...given my skill levels!   :D
« Reply #35 on: October 27, 2008, 06:45 PM »
Spen,
ta
Martin
I'll try and get a chance to measure it when I get home tonight Martin and pm you mate. I'm happy to send it to you and if it doesn't do the trick, you can send it back no worries. It's not NOS but it's clean enough mate, but we'll chat later.
Spen :daumenhoch:
Offline HUTCHMAN
« Reply #36 on: October 27, 2008, 07:19 PM »
i know it's probably a stupid idea,but what about getting the pitting "leaded"like they used to do in the old days with car bodywork.obviously would have to be VERY careful with the heat,but it's easy to sand down and will polish up good.
« Reply #37 on: October 28, 2008, 07:10 AM »
Martin - didn't get a chance to dive intot he shed to measure the sproket last night mate - late home, baby crying, wife knackered etc etc.... :knuppel2: I'll do it tonight with a bit of luck and send you a pic if I get a chance.
Spen :daumenhoch:
Offline Glynnyboy
« Reply #38 on: October 28, 2008, 01:40 PM »
As a few others have said, the grades of wet and dry is a mind numbing job but it will start to happen. The thing is with it being a hub it's awkward to get into so it feels like your getting no where. Just resign your self to chipping away a bit at a time. I did this with wet n dry and a lot of patience, didn't use the dremel until the last bit just to polish. What you have to remember about polishing is that, because the alloy has different strength metals in. Polishing will just polish and leave the pits, the surface has to be flatted 1st.
These are made of steel and a lot harder to rub down manually than alloy. It's just time and don't loose heart just yet.
« Reply #39 on: October 29, 2008, 08:48 AM »
Martin - it's 76mm across the tips of the teeth mate, so 5mm overall bigger. If you want to try it, let me know but I will try and get a pic with it on a Tuff flange as I have a spare one somewhere, I just need to find it :idiot2: :idiot2:
Spen
Offline funkyfresh
« Reply #40 on: October 29, 2008, 09:41 AM »
Spen,
sorry meant to reply back yesterday... been manic myself, an i havent got a baby!...just a nagging missues, but aint we all ;)
i'll PM you my address, and if you do the same, i'll send my 16t to you?
sound good?
M
« Reply #41 on: October 29, 2008, 12:11 PM »
No worries Martin
PM me your address and wait till mine arrives. If it's what you want and you're happy with the result, send me your 16T back. I'm in no rush as BMX takes a back seat at the minute (see previous post re: screaming child :2funny:)
If you manage to polish out the hub and want to keep your 16T, no worries, just send mine back - just trying to help out a fellow rider :coolsmiley:
Spen
Offline funkyfresh
« Reply #42 on: October 29, 2008, 05:32 PM »
ah Guys,
thanks for all your comments and help. Especially Spen who has made me a very kind offer...
Thats what this site's all about, and I love it for that reason!
cheers
Big love going out
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
M
