975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 07:36 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  GT forks, PRO???????????
Author Topic: GT forks, PRO???????????  (Read 707 times)
aditup 2234
« on: September 05, 2008, 10:49 PM »
if the forks are era correct, ie; from, lets say 83, was there any different specs?
I know BITD I had a pair which were undrilled. Were these pro? Is there anything other than drilled and non drilled?
cheers, Ad  :daumenhoch:
Offline Bananaman
  • Le Mans Man
Re: GT forks, PRO???????????
« Reply #1 on: September 05, 2008, 10:59 PM »
Yes Ad, two versions in 82/83 from what I know, lists them in this advert....
One for the 24/26 inch and the others for the mini, standard and the Pro, both none drilled.....solid dropouts ;)
Offline Bananaman
  • Le Mans Man
« Reply #2 on: September 05, 2008, 11:01 PM »
Sayin that if its late 83 with a slanted cut top tube they would have had square holes in the dropouts and drilled for front brake ;)
Offline Bananaman
  • Le Mans Man
« Reply #3 on: September 05, 2008, 11:19 PM »
AD, just had a thought.......
The early 83 GT Pro Performer had the same forks as the race frame so would have needed a hole for the front brake :-[
« Reply #4 on: September 05, 2008, 11:22 PM »
i want the early performer without the coaster bracket, anybody got one ?
Offline Moose
« Reply #5 on: September 06, 2008, 05:32 AM »
I'm way behind on GT's - did the Pro Performer come out as early as '83, without a coaster bracket and with Pro Fork?
« Reply #6 on: September 06, 2008, 08:28 AM »
thats cos you got no taste, go back to ya homolovingharoswiththebummergang...ok phil  :daumenhoch:
