975797 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 15, 2024, 06:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How do you repair a fork crown?
Author Topic: How do you repair a fork crown?  (Read 1021 times)
Offline Moose
« on: September 01, 2008, 06:36 PM »
I have a set of forks that has a small piece missing from the fork crown (where the crown race fits). I haven't tried a crown race yet, but can you repair them? If so how or is it not worth it?
Re: How do you repair a fork crown?
« Reply #1 on: September 01, 2008, 06:50 PM »
Is it like a chunk missing or all around ? Will it mean the race is wobbling about Phil?  ???
thesku11s
« Reply #2 on: September 01, 2008, 06:52 PM »
if the surface the crown race mounts to has a dent in it, I would just ride as normal as long as the crown race still fits. Wouldnt worry about it.
If its bad, I suppose you could eithet stick is straight in a lathe and machine the level to match the groove or braze in a filling and file it down, possibly also with some lathe at the end to make it tidy.
Offline sawzall
« Reply #3 on: September 01, 2008, 07:01 PM »
have you got a pic ???,but by the sounds of it you could build up area with a bit of weld and grind-file to shape ;)
Offline Moose
« Reply #4 on: September 01, 2008, 07:04 PM »
Right - off to get a picture  :daumenhoch:
aditup 2234
« Reply #5 on: September 01, 2008, 07:15 PM »
I would be reluctant to apply too much heat, if its going on a rider. They are heat treated usually, after the assemly and "tigging" has taken place, I believe. Get it too hot and you will screw up this process.
Ad
Offline southern andy
« Reply #6 on: September 01, 2008, 07:27 PM »
Phil, is this the same  problem i have with my Hutch forks i showed you. ??????????
Philip, sorry for the hijack mate but i'm interested to see if this is the same problem as i have.   :-[ :-[ :-[  :angel:
Offline Moose
« Reply #7 on: September 01, 2008, 07:42 PM »
Don't know if you can make it out or not ...............................
Offline sawzall
« Reply #8 on: September 01, 2008, 08:40 PM »
as far as i can make out by the pics there is a bit of the shoulder missing ??? if so just a bit of weld should build up area,and shape with sander-file ;)
thesku11s
« Reply #9 on: September 01, 2008, 10:08 PM »
have you not got a macro button (the flower!)  ;D
I suggest you get someone who works with lathes to spin the whole thing off. Then make a shim for applying the crown race,
I have to use a shim to convert between JIS and ISO, made a copper shim, works a treat.
« Reply #10 on: September 02, 2008, 06:01 AM »
Electrical tape can work wonders in situations like this  ;)
« Reply #11 on: September 02, 2008, 09:48 AM »
or strips of tin foil :daumenhoch:
« Reply #12 on: September 02, 2008, 10:13 AM »
I always used that special headset race shim material ... the stuff that come free around coke when you get it in a can
Offline stuntmaster
« Reply #13 on: September 03, 2008, 09:04 PM »
yep same as alex as had a few forks bitd that needed that ,never had a problem after
no1stuntmaster on instagram
