975791 Posts in 138942 Topics by 6363 Members - Latest Member: Bmxflex November 11, 2024, 03:55 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear Tuff II Issue...
Author Topic: Rear Tuff II Issue...  (Read 505 times)
GREMLIN
« on: August 20, 2008, 03:18 PM »
I’ve had a set of white Tuff 2’s with sealed bearings for a couple of years now and even tho they’ve been fitted to a couple of my builds i’ve never ridden on them.
I picked the rear out of the cupboard today and tried to spin it in my fingers and it felt seized. Out came the spanners and slackened the locknuts a little and the spindle started flapping about in the bearings.
What’s more the spindle is bent !!!.
So what’s the score with these?
They use a different sized spindle on the rear with different sized t.p.i. compared to the front. Why is this ?
The bearings are not the right size to hold the spindle snugly, so they wind the nuts down over-tight against the bearing face. To stop them rattling.
It was an easy fix by fitting a standard spindle in it’s place, which fits perfectly in the bearings.
Plus at least now i won’t need two seperate spanners to undo the front and rear wheels.
It’s not really  the point tho. It makes the standard Skyway package seem cobbled together.
Is this a normal problem with these newer Tuffs with the sealed bearings?                                 G.  :-X
Re: Rear Tuff II Issue...
« Reply #1 on: August 22, 2008, 08:03 AM »
seems strange Gav, I've got a pair of new sealed type on my lads bike and they run as smooth as silk from the box.....no problems at all.
who did you get them from mate?
GREMLIN
« Reply #2 on: August 22, 2008, 10:11 AM »
Hi Rob. I'm 99.9% positive i got them from Rudewheels. It was a while back and i can't quite remember.
There's nothing silky smooth about these rear bearings. No roughness, just like stirring syrup with a teaspoon  :)    G.
