975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 10:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tecmatic bearings
Author Topic: Tecmatic bearings  (Read 1143 times)
woody allen bars
Tecmatic bearings
« on: January 14, 2006, 11:21 AM »
Hey all, has anyone managed to source bearings for the Redline Techmatic bottom bracket? (the bearing dimensions are 38mm outer race, 28mm inner) According to my local bearing supplier the bearing is an OEM-type fitting and needs to come from Redline, but since the Tecmatic disappeared over 15 years ago that's probably not going to happen.
Any suggestions?
Craig
Offline Rombloke
  • do one
Re: Tecmatic bearings
« Reply #1 on: January 14, 2006, 12:29 PM »
yes go to your yellow pages and look up your local bearing suppliers.
my local one is called j & m belts, when i used to have a kart i used to get the engine bearing from there. from a specific kart shop they would be about the 50 quid mark for the kit, from the bearing guy they were about 12 quid, and of a higher quality. he stocked sealed and loose bearings in every imaginable size, its worth a try
Dave
haro, how do you do
woody allen bars
« Reply #2 on: January 14, 2006, 06:26 PM »
Thanks for the suggestion Dave but have already tried that. They looked right thru their whole catalogue of bearing suppliers with no luck as it's a pretty unusual size.
wirewheel
« Reply #3 on: January 24, 2006, 01:25 AM »
try this place, worth an email?
Bearing Specialists Ltd
36/40 Snowhill
Shelton
Stoke On Trent
Staffs
ST1 4LY
tel: +44 (0)1782 214822
fax: +44 (0)1782 287324
email: bearingspec@hayley-group.co.uk
allegedly one of the biggest bearing suppliers
« Reply #4 on: January 24, 2006, 07:22 PM »
you got a pict of wot they look like as ive some bearings with a huge hole in the middle lol
