975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:31 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  freewhell info wanted
Author Topic: freewhell info wanted  (Read 1560 times)
2020mad
« on: January 13, 2006, 10:42 PM »
What is the smallest size freewheel you can get for a normal rear wheel without having a casette hub ? cheers.
Offline billstup
Re: freewhell info wanted
« Reply #1 on: January 13, 2006, 10:46 PM »
13 t I think  :daumenhoch:
« Reply #2 on: January 13, 2006, 10:58 PM »
But that 13 tooth freewheel will not go on a good old fashioned hub...  I made that mistake   :'(
I stand to be corrected, but I think a traditional flip flop hub has the smaller threaded area on one side of it which will accomodate the wee freewheels.
I think   :-\
2020mad
« Reply #3 on: January 13, 2006, 11:02 PM »
Its just your old standard screw on type hubs ive got.   what about a 14T ? or am i stuck with 16T?
Offline billstup
« Reply #4 on: January 13, 2006, 11:07 PM »
You are right Rob, a normal freewheel only goes down to 16 t, but I thought 2020mad ment what is the smallest freewheel that goes on a hub that is not a casette hub, i.e a threaded one  :idiot2:
Perhaps we need more info  :daumenhoch:
« Reply #5 on: January 13, 2006, 11:09 PM »
You're stuck with yer 16 I'm afraid.  I thought I could run a 15t on my Superpro hub - Nope!   :tickedoff:
2020mad
« Reply #6 on: January 14, 2006, 12:02 AM »
Hmmm guess i won't be fitting 28T chainring tommorow then,  28-16 ratio a bit stupid.
Will have to start saving a bit more for some new wheels.
Nana
« Reply #7 on: January 14, 2006, 12:06 AM »
You need a 10 to run a 28 teeth sprocket but it various but nowt by much you can run a 10x28 ,29,30,31 most common on new rides are 13x36
Offline Rombloke
  • do one
« Reply #8 on: January 14, 2006, 10:45 AM »
ok the easiest way to work out gearing is to head for an average ratio of 2.75.
this is acheived by diving the front sproket size by the rear
i.e 44 / 16 = 2.75
so if you wanted to run a 28 tooth front, then that needs to be divided by the 2.75 which equals 10.18.....so as nana says you will need a ten tooth driver.
44/16
42/15
40/14
39/14
36/13
33/12
30/11
28/10
25/9
22/8
hope that helps....i feel nerdy now
Dave
haro, how do you do
power
« Reply #9 on: January 14, 2006, 11:00 AM »
the smallest freewheel you can use on normal size threaded hub is 15 http://www.alansbmx.com/product_info.php?products_id=1179
you will need a flip flop hub to go smaller than that
2020mad
« Reply #10 on: January 14, 2006, 11:04 AM »
Thanks :daumenhoch:
« Reply #11 on: January 14, 2006, 08:40 PM »
Aah.....  Specialist item.  Nice.  £20?  even nicer.  Wish i'd seen that.... :'(
