976222 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 08, 2026, 04:53 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline Flite crank advice HELP!
Author Topic: Redline Flite crank advice HELP!  (Read 1111 times)
Offline generallee
« on: August 09, 2008, 11:21 AM »
I have a pair of the twin pinch new school flite cranks - but no chainwheel to go with it. Im gonna use a reglar powerdisc/ring, but want to check someting from anyone who knows...
the axle deems much smaller than the regular 19 or 22mm bore that most axles and chainrings have ... would a top hat washer in a regular powerdisc fit, or will the ring still be loose on the axle? Are there specific rdline top hat washers I need? Any help appreciated!
« Last Edit: August 09, 2008, 11:24 AM by generallee »
Re: Redline Flite crank advice HELP!
« Reply #1 on: August 09, 2008, 12:05 PM »
they are the same as profile 19mm steve well im pretty sure
Offline generallee
« Reply #2 on: August 09, 2008, 03:17 PM »
cheers dan - should be fine then!
steve Beech TA
« Reply #3 on: August 10, 2008, 07:33 AM »
I am sure you get one in the rl box, if that is any help :daumenhoch:
