975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 21, 2024, 09:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  990 brake plate question
Author Topic: 990 brake plate question  (Read 947 times)
Offline Gary72
« on: August 01, 2008, 04:52 AM »
Is it possible to fit one of these on the rear and on the underside of the seat stays like new school bikes and use a hombre
Not sure if it is my memory, but i'm sure at one point I had my caliper brake fitted underneath BITD :idiot2:
Thanks
Gary
Re: 990 brake plate question
« Reply #1 on: August 01, 2008, 06:53 AM »
You could, yeah.  The problem is all the braking forces will be trying to pull the whole assembly down and its gonna flex like mad, the frame back thre is nowhere near as beefy as the forks are...  If you could secure the plate arms to the frame with jubilee clips or big fat cable ties (thats what I did when I ran one) that would help a great deal.
Your other option I suppose is to mount it on top of the seatstays to eliminate that problem  :)
« Reply #2 on: August 01, 2008, 08:56 AM »
you can deffo use a plate on the rear end........if my memory is correct i think Mr Dan Harris had/has one on his Trick Star rider??
« Reply #3 on: August 01, 2008, 09:19 AM »
you must strap it to the frame though like rob says
the teeny bolt wont hold it
fat cable ties will work ok, jubs will be best
alternatively just weld some lugs on it.
Offline Gary72
« Reply #4 on: August 01, 2008, 11:07 AM »
Thanks guys, will have a look for one at MK :daumenhoch:
« Reply #5 on: August 01, 2008, 03:06 PM »
i have one you can have.
Offline Gary72
« Reply #6 on: August 02, 2008, 03:14 PM »
Your probably at MK now, so will add you to my find this person list :daumenhoch:
« Reply #7 on: August 02, 2008, 03:27 PM »
Just look for a bloke doing endo tricks and you'll find Gra  :daumenhoch:
