975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 01:30 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  '07 Hoffman Condor spindle length?
Author Topic: '07 Hoffman Condor spindle length?  (Read 702 times)
Rake
« on: July 31, 2008, 02:45 AM »
Spanish BB, 19mm diameter, but unsure as to what length...  there are 5 1/2", 5 3/4", 6"...any help?
HEYWOOD BMX
Re: '07 Hoffman Condor spindle length?
« Reply #1 on: July 31, 2008, 08:20 AM »
 :) Would have thought that depends on what cranks you are running??
Rake
« Reply #2 on: July 31, 2008, 08:45 AM »
As of right now I will be recycling the crank arms from a set of Haro Fusion cranks, but I need to replace the spindle as the old one I had was threaded.  I'm mainly wondering how much clearance I will need.
« Reply #3 on: July 31, 2008, 08:50 AM »
you say it's theaded?  but i'm guessing you still have the spindle though?  if so bang it in and see if it's okay then go for one the same size? or add or take away as needed??
failing that buy a new crank set with spindle..........as a fail safe get the biggest and use spacers?
