975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 11:02 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  New parts "in the works" from S&M
Author Topic: New parts "in the works" from S&M  (Read 2601 times)
« on: July 19, 2008, 11:23 PM »
As stolen from the S&M site:
In The Works
Here are a few new ideas we've been working on and testing for awhile.
The first one is a regular railed seat that works with a Pivotal seatpost
with the use of our new guts. We like the single bolt assembly of the
Pivotal system but really like railed seats for 3 reasons: the look, the
flex, and the ability to adjust front to back. these guts have passed the
testing stage and are being made now. We are also making a seat for this
system but any railed seat will work after you cut a small slot in it for
the Allen wrench. We also like to peel the padding and cover off first but
you don't have to.
This rear drop out uses a hub with a hollow axle and bolt. This drop
hasn't had the taper machined into it yet but when it does it fits the
bolt perfectly. We are testing this now and it's working out great. The
drop out never closes up and you can slam your wheel and have it tighten
the chain automatically due to the tapered bolt. We call this the "Black
Hole". This thing is awesome and it's super clean.
Shimano DX cranks used to have thread in cups that sat on the outside of
the Euro BB shell. Now they are working on a plastic BB system that
presses in. It works great but requires a new BB from the frame
manufacturers that is asymetrical...we are riding them now and they work
really good. This might also allow street riders to use shimano cranks
without fear of grinding down the outside of the cups. It also makes
putting your bike together way easier. No need for a special tool for
instance.
Last up is a Lexan sprocket with guard. This thing is light but expensive
and we're not having the best of luck with it yet. Not only is it breaking
but the teeth are getting mangled pretty eaisily. This may go the way of
the original plastic Addicks sprocket but we're not done yet. The idea was
to make a gaurd sprocket that slid really good. We're still working on it.
These are just a few of the things we are working on...we just thought it
might be cool to show them off. What do you think?
Chris
moeller@sandmbikes.com
Re: New parts "in the works" from S&M
« Reply #1 on: July 19, 2008, 11:31 PM »
My thoughts so far:
Im into the seat guts Idea as it would be way better than most seat guts, but it would be a bit of a pain to tighten up .... and I wont be ripping the padding off my seats!
I LOVE the dropout idea, even tho Im not totally sure how it keeps your chain tight. I have been saying for ages why dont they make forks like this? Forks that can only be used with "bolt" front hubs.
I dont understand the shimano BB, maybe dailledMike can help out with this one ???
Plastic Chainrings are still crap, but you dont hit balls out of the park without missing a few :daumenhoch:
Offline billstup
« Reply #2 on: July 19, 2008, 11:45 PM »
Is the dropout thing like shimano cranks used to be where you could adjust the length by 5mm or so ?
The boss for the pedal could be turned,.......................... it`s a bit hard to explain tbh  :idiot2:
Offline kev-s
« Reply #3 on: July 19, 2008, 11:56 PM »
saw this on the site earlier today and like the dropout idea , not too sure on the pivitol seat idea or the plastic chainring though and why go back to euro size bb when mid seems to work perfect?
subversion
« Reply #4 on: July 20, 2008, 12:32 AM »
Looks like one big piss-take to me!? :D
Lazarou
« Reply #5 on: July 20, 2008, 09:18 AM »
Back to railed seats is a good idea to me, i've never liked those pivotal ones.
With the dropouts wouldn't you have to keep changing chains when they stretch a bit?
I know nothing about those Shimano cranks other than i hate them.
The sprocket i don't know about, i just hope Chris isn't throwing too much money at it!
That's my bigoted, uninformed opinion.
« Reply #6 on: July 20, 2008, 09:54 AM »
The dropout intrigues me.  I'd have to see the finished version to fully understand it though.  I'm assuming that the slot will be both countersunk to suit the bolt, and tapered to enable the auto chain tension thing, as you tighten it the bolt follows the taper backwards and hey presto?
How do you lock it all off tight though?
I'm confused, me........ :-[
Lazarou
« Reply #7 on: July 20, 2008, 09:56 AM »
That's easy for you to say Hawking!
Offline Philbert
« Reply #8 on: July 20, 2008, 11:33 AM »
i'm with alex on the forks. thought that about allen bolt only forks too! something for odyssey maybe!
i'm with laz on the rear dropouts, your fooked when the chain stretches
plastic chainring ffs! not on my watch!
i've had a pivotal seat/post. super light but no adjustment. went back to rails, much happier. can't see the point in what they're doing on this, the weight saving on a pivotal system is the lack of rails on the seat, if your gonna use rails, just get a micro adjust seatpost!
the bb thing! from what i can understand shimano dxrs only come with the 'x type' bb (external bearings), its a brilliant design and have had this type on my mtbs for a few years now, what it looks like shimano are trying to do is widen its market of the cranks so they're not just for racing frames with a euro bb. kind of a conversion kit if you like, the assymetrical bit comes in with the bush size. if you look at the pic the chainring side has a bigger bush as that side will take more load. is this the next generation of bb?! can't see it myself! but then again shimano do have a little bit of weight in the cycle industry!
« Reply #9 on: July 20, 2008, 02:12 PM »
From what I can see, the rear dropout is an enclosed SLOT, that only has about 5 or 10mm of adjustment. Closed so it wont close up from grinding (with our without pegs) but with a small amount of adjustment for all gearings and when your chain stretches. I think that when you slam your wheel all the way forward (if you get the gearing and chainlength right) you can use the angle of the countersunk bolt to give a small amount of pressure pushing the wheel back, and meaning it cant move forward. Im not totally sure if this is what they are saying, or even if it would remain tight if the bolt was only contacting on some of the angled face. I do like the closed dropout tho.
evamedia
« Reply #10 on: July 20, 2008, 03:01 PM »
With asymetrical frames for the BB thing, you'd then need LHD and RHD frames, another different combo for the shops to stock.
thesku11s
« Reply #11 on: July 20, 2008, 09:49 PM »
and with the larger bottom bracket (steel) is kind of outweighs (pun!) the weight benefit of not having the external cups.
They mention riders will be able to avoid grinding the cups, but the cups are replaceable so whats the problem with grinding them?
dialledbikes
« Reply #12 on: July 21, 2008, 12:04 AM »
I'm no street rider, but I would be more worried about grinding/fooking up my £260 cranks arms than my £35 BB.
« Reply #13 on: July 21, 2008, 02:10 PM »
why dont S&M just steal the design that VG had for thier seat guts n do em to fit old school posts too, not that id be first in line or anything ::)
JT71
« Reply #14 on: July 21, 2008, 02:33 PM »
no plastic and no pink eh Phil?
 :LolLolLolLol: :LolLolLolLol:
Offline Philbert
« Reply #15 on: July 21, 2008, 07:19 PM »
fookin eh!
JT71
« Reply #16 on: July 21, 2008, 08:14 PM »
secretly you covet plastic parts....in  pink.
 :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol: :LolLolLolLol:
DanCressy
« Reply #17 on: July 21, 2008, 11:42 PM »
you guys crazy, s&m have gotta be taking the piss.
« Reply #18 on: July 22, 2008, 05:39 PM »
wouldnt last long in ure hands aye dan lol
subversion
« Reply #19 on: July 23, 2008, 03:00 PM »
I was wondering how long it would take Russ to jump on this ;)
http://sprfls.blogspot.com/2008/07/s-next-generation-holmes.html
« Reply #20 on: July 23, 2008, 07:41 PM »
I love and live by SPRFLS, and once again Russ takes it on and says everything right.
I feel very close to the SPRFLS site. I agree with loads of it, I like the links and comments. I even know most of the obscure pictures and references he uses. I sometimes hope to find out that I am Russ, and the SPRFLS is something I do at night, when Im sleeping.
Lazarou
« Reply #21 on: July 23, 2008, 08:40 PM »
I AM RUSSICUS!
subversion
« Reply #22 on: July 23, 2008, 09:36 PM »
NO! I'M RUSSICUS!!
« Reply #23 on: July 23, 2008, 09:47 PM »
No, Im Sporticus, and so is my wife!
(how was that for mulit referance?)
