sorry mate i thought someone would've by now!what i did mith mine was to take the old axle out and change the barings and re-grease.....then put it all back together and then filed down two small flat spots on each side so they slipped into the forks......making sure not to go too deep on the axles though i'm not sure the flattened axles are easy to get hold of new??
i might have an old axle with the flats bits you require but only for open bearing hubsLYK, soon
Hi m8i have one out of an old SR hub 10mm axle so will fit all open bearing hubs, i'll get it inthe post asap, free Jai
cool there you go mate.........as for my filing effecting the thread? well i only filed where the forks would fit over the axle, so the axle nut didn't go over that section
